I think 1" of travel is plenty for knife work.Anyone see why this x axis mount wouldn’t work? It only has 1” of travel compared to the 2” posted way back.. the other one posted is not available right now through the link but is $125 on eBay. I found this one that is similar and USA built..
https://www.ebay.com/itm/ALM-LA2-3-...riorityMailPaddedFlatRateEnvelope!02134!US!-1
The magnets look pretty cool the only thing it, they would need to be very close to the work piece, ideally touching it. It would be a matter of using an aluminum bar that is slightly thicker than the magnet mount depth to allow for surfacing. you would also need to be able to make the hole in that bar for the magnet. Preferably square.Have you guys seen the new Black Fox surface grinder? It's using passive magnet switching for the chuck. You can see the preorder here https://blackfoxknifeworks.com/knifegrinder/black-fox-glide-surface-grinder, and it looks like the magnets are from https://www.kjmagnetics.com/blog.asp?p=magswitch.
They are rather cheap at only $34.95: https://www.kjmagnetics.com/proddetail.asp?prod=MJ-150.
I don't know if the implementation of the magnets is versatile. You can't load up smaller parts across the chuck and surface everything together. For example, multiple sets of slipjoint blades and backsprings.
I do like the looks of that setup - the 1" of travel isn't a problem at all. The 2"X2" pad on top is smaller than I'd like, but if strong/rigid enough should work.Anyone see why this x axis mount wouldn’t work? It only has 1” of travel compared to the 2” posted way back.. the other one posted is not available right now through the link but is $125 on eBay. I found this one that is similar and USA built..
Out for delivery today so I’ll know tonight haha. I’ll have to post back with how it works out. All parts are on order, soon to start assembling.I do like the looks of that setup - the 1" of travel isn't a problem at all. The 2"X2" pad on top is smaller than I'd like, but if strong/rigid enough should work.
Still have to epoxy the magnets in?
I meant to comment on your blade slipping on the chuck when grinding. There are two methods I use to prevent this. One is to use a thin bar perhaps 1/2" wide and thinner than the blade you're grinding. Put in a magnet slot so it will catch on the edge of the aluminum that rises above the magnet. Another simple method is to drill an 1/8" hole in aluminum chuck perhaps 3/16" deep. Stick an 1/8" brass rod just long enough to stick above the aluminum the thickness of the tang. You do have a hole drilled in tang? Put the brass rod thru the hole in tang and it will hold blade in place while grinding. Either method works pretty good.
I'm a total newb, but I can definitely see the usefulness of this just in the small number of knives I've made.
I'd like to try one myself, but I don't have access to a mill. Is the chuck the only piece that actually needs to be milled? Everything else more or less bolts on?
I got the idea of the bar across the chuck from one of Travis's videos on his SGA. Even with N52 magnets there will be sometimes the blade will try to slip, especially with smaller blades and heavy grinds.hose are great ideas to handle weak magnets. I would have to use the pin method to secure the blade from slipping. The magnets are level with the face of the chuck. I ordered N52 magnets, and will be remaking the chuck. This time I will set the magnets 1/8" deeper into the chuck. I am curious what size of magnets and strength the TW SGA uses.
