David Nowlin
- Jan 17, 2018
While hiking I use a small titanium pot with a bail to boil water
Some people you just cant please. If you start a new thread they yell that you should have used the search function. If you revive an old thread they yell you should have started a new one. Oh well. I haven't ran into that on this forum yet but I'm sure I will at some point.
Another use for the hook. While hiking I use a small titanium pot with a bail to boil water. I have used the hook to lift the pot by the bail when I was dumb and left the bail down to get licked by the flames.
True enough, I tried replacing the hook with a corkscrew but it didn't give the correct tension, the scissors went all mushy. Hmmm, I wonder how hard it would be to file the hook down into a thin marlinspike? I'd wanted a corkscrew because it's great for opening knots but a marlinspike is better. Would need some careful work of course to round out the shaft of the hook, it's pretty thin to start with.By far the best use for the hook is filling out the backspring side of the scissors
How would you open it? The end of the hook has the nubbin on it for opening it.True enough, I tried replacing the hook with a corkscrew but it didn't give the correct tension, the scissors went all mushy. Hmmm, I wonder how hard it would be to file the hook down into a thin marlinspike? I'd wanted a corkscrew because it's great for opening knots but a marlinspike is better. Would need some careful work of course to round out the shaft of the hook, it's pretty thin to start with.
