- Mar 10, 2010
Return to the seller. Do some reading and research. Spend your money on something else.
Um, what about this was actually custom made?Well of course it came with a handle, it just wasn’t custom made with the blade.
The bladeUm, what about this was actually custom made?
Ok, I'm not trying to be negative here, but are you sure they actually made the blade? It sort of looks like a Pakistani damascus blade. What seller did you buy it from?The blade
I got it from MikesDamascus on Etsy, he custom makes the blades and sends updates with pictures as it’s made.Ok, I'm not trying to be negative here, but are you sure they actually made the blade? It sort of looks like a Pakistani damascus blade. What seller did you buy it from?
It doesn’t stay closed when the knife is moving. If it is shaken or jostled then it partially opens.I am confused. Is this a NEW directly from the custom maker or has it been through some middle man/men? It looks to me like a well-used one.
A detent hole larger than the detent ball does not automatically result in detent rock. OP - what do you mean by it does not stay closed well. Does the knife has lock rock when the blade is in fully closed position?
There is definitely movementOK - not that I'd buy the knife or sing praises for the maker, but to me $73 does not seem to be a ridiculous price.
OP - my question was: while the detent ball still sits inside the detent hole, does the blade move if you shake the knife? If yes, it has detent lock and indeed the large detent hole is a problem. If not, then your knife has weak detent, which usually can be resolved or at least improved by bending the lockbar inward.
Totally. That thing looks fresh out of the truck stop.I found the seller and the knife the OP bought. Looks like the seller uses kits for the knife handles. I'm not entirely convinced he actually makes the blades. Maybe he does.
For $73 you can get a nice knife with a warranty.
If you want budget damascus...
For a knife that doesn't work it is.to me $73 does not seem to be a ridiculous price.
Agreed. Hopefully this kid will learn from this experience.You wanted a “custom” for $73.00.- Then you question the quality. This post is hilarious.
