Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Yeah - srsly.survival situation srsly
you mean you're in the Rocky Mountains, got your gear stolen incl. your portable sharpening stone RRS, found a dull knife in a lodge, and need to sharpen it to save your ***?
i'd go to the creek and fetch a smooth stone and a fresh mackerel. like they did in yellow stone.
If that first thing happens, one way or another you're not going to be running around long enough for your knife to get dull. Likewise if you take your car off a cliff and can't hike back up to the road to get help, finding a river rock to sharpen your knife is not on your list of concerns.Imagine you are a soldier, you throw your backpack somewhere because enemy fires at you, you survive the situation but backpack is nowhere to be found. I agree that it really depends on situation, but if you are staying in the woods for more than one night and no contact with outer world, it's little worse.
Assuming you survive a fall off a cliff , what you intend to do with knife in that week before they found you so the knife get dull ? And what is dull knife , what do you think ?Yeah - srsly.
Maybe not necessary to worry about if you live in the Netherlands, don’t plan to travel, and can’t get lost because there’s so little forrest left, but in the US where I live, there are TONS of places you can get lost and TONS of places where you could slide your car off a cliff and not be found for a week. (You keep a carbon steel fixed blade in your car I hope?)
Maybe not the most likely skill to need, but nothing to scoff at.
First things first is be extra mindful not to needlessly damage your edge so you don't have to touch it up in the first place. But as already mentioned, if you intend on possibly being in a setting where improvised sharpening might need to be done, make sure the knife you carry is one in simple low-carbide steel in a softer heat treatment so it's able to be suitably abraded by quartz grains.
One method of doing light maintenance touchups is by carving a flat on a piece of wood, pricking it with the point of the knife to create a series of small "wells" and then find some find siliceous sand and rub it on the surface, preferably with some sort of grease, pitch, or other substance to help the grains cling. You can then use it like a strop.
It doesn't work great compared to a proper stone, but it's better than nothing by quite a stretch!
Finding suitable stone really depends heavily on your locale. Good sharpening stones with different performance qualities were a precious resource and were traded far and wide since antiquity because of how unsuitable most stone is for such an application. But if you ARE lucky enough to find some stone in your area that works well (keep an eye out for sedimentary rock, specifically) take two pieces that are as flat as you can lay hands on and rub the faces together in circular/figure eight patterns to lap them against one another. There's some very fine black siltstone in my area that works great as a finishing stone, and happens to like to fracture in roughly trapezoidal patterns that means many of the found pieces are already fairly flat, with some being flat enough to use as-is so long as you go edge-trailing. Rubbing them against one another with a bit of water on them to keep them clean and abrading at each other produces a fine slurry that easily wipes away. But it's a lot of work even with an ultra-coarse diamond plate or loose silicon carbide grit and a lapping plate, let along the self-lapping method, so it's something best done only if truly necessary.
I've especially used the method when sharpening things like gut hooks for people when I was away from my full range of sharpening supplies. Use the dulled gut hook to carve a stick to a precise fit for the slot, then apply the sand/fine dust to the wood and strop. Like I said, it's not the BEST method around, but it's one of the most field-expedient and works well enough for touchups, especially if your knife or other cutting tool is a basic carbon steel that sharpens on just about anything.That strickle idea is ingenius.
Maybe chop some wood (hopefully there’s wood) maybe dig a hole, maybe baton through some of the sheet metal of my car to make another tool.Assuming you survive a fall off a cliff , what you intend to do with knife in that week before they found you so the knife get dull ? And what is dull knife , what do you think ?
Most situations, that’s probably correct, and there are lots of things that PROBABLY won’t happen in a generalized survival situation, but to state these likelihoods as facts is a little overboard.If that first thing happens, one way or another you're not going to be running around long enough for your knife to get dull. Likewise if you take your car off a cliff and can't hike back up to the road to get help, finding a river rock to sharpen your knife is not on your list of concerns.
If you went out with a decent knife in good shape no emergency situation is going to last long enough for your knife's edge to ever become a problem and in an emergency spending time and energy looking for a suitable stone to rub it on is a mistake. If you've cut so much wood and rope that your knife has stopped working completely and you aren't safe yet, say your prayers and write a goodbye note.
The best thing for that is some extra pounds around the waist for those long cold nights in the bush.Most situations, that’s probably correct, and there are lots of things that PROBABLY won’t happen in a generalized survival situation, but to state these likelihoods as facts is a little overboard.
I live in CA around lots of cliffs and I have read about and personally searched for people lost in the woods for multiple days.
Your post implies that because you think it’s an unlikely skill for someone to need, it’s a silly thing for others to learn…
They do? Always? Sounds like an opinion stayed as a fact.1. Can you hike out? Get walking. If you ended up somewhere more than a couple days walk from human habitation, in dangerous weather, with no equipment... you are going to die because people with skills make sure their gear is with them when they are in places like that.
Any stone you can find near your wild path is the best !But what type of stone is best? Where will you find stones that are best suited for sharpening?
