- Dec 29, 2021
Once burned, I get that.
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
I always disliked this about MT. I’ve been lucky to get M390 blades but if I was to get an Elmax I’d return it. I’m not a fan of Elmax at all.
It’s irrational really. I had a ZT Elmax blade years ago and it had a horrible heat treat and ever since that I’ve not been a fan of Elmax or ZTs
I was all ready to read a post that bashed me for not liking Elmax. Not what I found. Your post was well thought out and very informative. Thank you!I hate to burst your bubble, but you should go check out the various cut tests of industry standard HTed M390/20CV/204p on YT. Outpost 76 is one such channel and he has posted at least a couple videos showing that Microtech's M390/20CV/204p didn't have great edge retention, certainly not anything close to what the steel is capable of. There are videos of this steel from other makers and many have the same issue. Seems particularly bad with the Italian brands.
He also has a link to all his test results and that of others for various steels in Google sheets so you can see how industry standard HTed M390 with relatively poor edge retention is an industry-wide problem. That sheet allows you to compare it against other steel's performance and see how many of these steels shouldn't be doing so much better than M390/20CV/204p, but they are. There are a few makers who do this steel well however, unfortunately, they're in the minority.
There's another really great vid by Tom Hosang Outdoors channel called "Microstructure matters! (testing 10 blades in cts-204p) ft. transparent knives" which explains some of the problems and how various HTs affect this steel and how Rockwell hardness alone doesn't really tell you much about how well the steel will perform.
Similar but opposite to you, and due to this issue, I have an aversion to M390 unless I know the maker has a history of HTing it properly. Funny enough, it's why I am leaning towards Elmax in Microtechs instead of M390 though!
That said, I have no objective evidence that their Elmax will perform any better with regards to edge retention than their M390. I'm just hopeful that it will be better as the issue with M390/20CV/204P seems worse than with other steels. I do have knives of theirs in both of those steels and I intend to do some controlled cut tests to find out though.
As a final note on this, I'm not trying to bash any makers and certainly not the steel. It still works and will serve people well. It's just that a lot of the steel's potential is left on the table as far as edge retention goes unless it's heat treated with this goal in mind.
Another of the big problems in the industry is the overheating of the edge when manufacturers put their edges on with high-speed dry grinding. This causes greatly reduced hardness of the edge which negatively impacts performance. It often takes a number of sharpenings to get back to properly hardened steel before you see the edge retention go back up to where you expect it to be.
This is likely the issue you encountered with your ZT. I say this having owned several ZTs myself where I could visibly see the edge was burned since it was all bronze and purple colored!
I encourage at least several sharpenings of a knife using consistent angles and edge finishes before evaluating a blades true performance. It will typically go up as the number of sharpenings increase and you get back to properly hard steel. The tests by Outpost 76 on YT show this really well.
Here's a great post on this topic. Be sure to check out the references linked at the bottom of the post as well :
KKnives Switzerland on Instagram: "If you follow me for a while, you may know that I always promote and emphasize wet grinding and wet/hand sharpening. This is yet another stellar example as to why: A fellow knife maker and friend asked me to micro v
366 likes, 109 comments - kknives_switzerland on February 23, 2021: "If you follow me for a while, you may know that I always promote and emphasize wet grinding and w..."www.instagram.com
That could be. I had a StormTrooper but I cannot seem to find any pics of it saved anywhere so I just can't say with certainty that it did have the engraving. It is possible that the cerakote knives don't have it. My Ultratech with the black DLC blade does have the steel engraved so in my head the StormTrooper did too, but I could be wrong.None of the Star Wars models I’ve owned
Show the blade steel, maybe just an aesthetic choice, I’ve not lost any sleep over it but it would be nice if at least the box listed the info!
I assume they’re not using 440A on these but who knowsThat could be. I had a StormTrooper but I cannot seem to find any pics of it saved anywhere so I just can't say with certainty that it did have the engraving. It is possible that the cerakote knives don't have it. My Ultratech with the black DLC blade does have the steel engraved so in my head the StormTrooper did too, but I could be wrong.
They make their Elite model in the USA for us AmericansThe Socom Bravo actually looks most attractive to me among all their models but yeah since it's made in China let's all take a dump on it.![]()
I'm still waiting on an out the rear model.
I'm willing to pay out the rear. I mean with Microtech, that is expected.How much you gonna pay for one?
So it automatically pops out and it's in a reverse grip? That's mall-ninja smart right there!I'm still waiting on an out the rear model.
I never said that, lol. I just think it's lazy of them not to list what specific steel they're using on any particular model.Whatever steel they use, it is probably suitable for a knife blade.
Do you think they would use a non-hardenable steel like 316 stainless, or some zink based potmetal?
