Ethan Becker
Moderator
- Sep 1, 1999
Hey HK Guns....
Bone is unpredictable as all get out.... Angle of attack, temperature, thickness, and the age and diet of the critter( which will affect density)will all make an interesting and unpredictable mix... Cow leg bones are the absolute worst in my experience. they are absolute hell on a blade. I did a lot of bone chopping tests in the Eighties and generally found no probs with neck and rib bones but the larger animal leg bones seem to be(as one would expect)very tough and a nightmare. Cuts made at zero degrees obliquity are the most likely to damage the edge...cleavers which are designed from chopping through Bone are generally Appleseed ground to a thickish edge and heat treated to a fairly low Rockwell. Dis jointing is always prfeble and if you are trying to get at the marrow use the spine to hammer your way in.
e
e
