horseclover
Basic Member
- Nov 21, 2000
nevermind
Im actually a sword smith and i hate the grind ever so, and the thought of grinding away that much 3v on stones gives me a headache, much less the thought of cleaning out fullers. Yuck.
So how to explain this... A billet would be laminated in large thickness and then forged into a bar 18 inches long with 3/8ths thickness by 1 inch wide, with two tapers from 1 foot and 6 inches down to half an inch. It might weigh 3-4 pounds depending on the content. The mass is distrubuted now to form the balance. The bar then might get flattened down and stretched to .3 or even as thin as .2, and the blade section is beveled and spine stretched distally and longitally down to the spine at the tip to as thin as .1. Giving the blade length of 24-29 inches (historically reprosentative blades are never longer then this)
The result is that there is ALOT of steel in the tang and despite weighing 3 or more pounds there is enough mass in the tang to put the balance point with fittings at right where you would grip it, sometimes an inch above or below depending on the smith.
Despite being heavy all of the weight ends up in your palm and the leverage point pivots around your center of gravity.
(I swing a 4lb hammer so i dont think anything of this weight)
CPM 3V, damascus, terotuf, corby bolts and epoxy! What a really cool meeting of the traditional and the modern.I've been slowly putting together a non-traditional katana in CPM 3V steel and posting many of the steps over in Shop Talk. This is my first attempt at a sword after making about 30-40 knives in various styles. Since it is just about finished I thought I would post a few pics of the completed project over here. (I still have a sageo cord on the way)
The blade was made by stock removal from 3/16" thick 3V, heat treated by Peters to 60 hardness. I hand-filed a tsuba and made other fittings (seppa, fuchi and kashira) out of damascus.
The core of the handle is terotuf, assembled with corby bolts and epoxy (can't be taken apart).
I did a full covering with rayskin wrapped with silk ito over gold plated menuki.
The cost of the parts alone is more than any "battle-ready" sword on ebay, but I learned a lot and have something that I won't be afraid to do some chopping with.
