- Sep 19, 2017
I'm moving over from the Worksarp System (Ken Onion + Blade Grinder) to a KME. I've used the Worksharp for years, and many times I get good results, but sometimes the blade makes contact with the roller and gets a "rash" -- or the edge of the scale may make contact with the moving belt, causing a rash on the scale (which is less common but happened at least once). Now that I have some expensive knives, there is less room for error. I'd like to sharpen my Olamic 247 at some point, and there's no way I'm doing it on a WorkSharp. Anyway, this thread is really about the KME; just wanted to explain a bit about why I'm changing systems.
So I bought the basic KME kit + stand. I'm also going to buy some glass blanks and some 8.5x11 lapping papers on Amazon and cut 1x4 pieces out of them. (The papers on Amazon seem to be the most economical, and I figure a spray adhesive should work to fix the paper to the glass.) I've watched some videos on youtube to learn from others' mistakes, and I think I have the basic idea, but I still have some questions for you KME people:
- Some people (Cedric & Ada and others) mention that the blade can get scratched. Some attribute this to diamond dust, and some attribute this to some sort of wobble in the stone. Do I need to tape over the non-cutting surface of my blade? I was hoping that by moving over to the KME that I wouldn't have to do this.
- The basic kit does not come with the the Beast (50-grit) or the 100-grit stone. Everyone says to get the Beast, but some people say you don't really need the 100-grit stone. I figure I'll crowd-source this question to you guys. Is the 100-grit stone necessary, or not?
