Appreciate the info. I have another question (sorry OP, not trying to derail but figure this information would be useful to you as well)…I watched multiple Hapstone videos last night and everyone kept talking about the flex of the clamps. Seems like an issue that they tried addressing with the updated models but it seems like it’s still there.
So the question is….How bad is the flex and has this been and issue for you?
Yes, there is a little bit of flex in the Hapstone clamps and any other knife clamp system for that matter - depending on how hard you push on the blade when sharpening. You can get any clamp to flex with enough force applied. Hapstone, TSPROF and KakBritva (as an example) have many clamp options, and the longer and thinner the clamps are, the more added benefit of lower sharpening angles with smaller blades. Some whole milled clamps have less flex than some spring steel plate clamps, but some spring steel clamps conform better with full flat grinds - just as an example.
The clamps will not flex much at all after your knife is securely clamped - something a lot of these "expert" reviewers on Youtube don't even mention or realize. Once the knife is properly clamped, it becomes more secure because the clamp top ad bottom basically make a triangular brace structure with the knife blade at its center - basic engineering "101". If the clamps are pushed down and flexed
without a knife in them, then the flex will obviously be much more. It
is a clamp after all and
needs to flex to actually do what it's designed to do - close up and reach the knife blade to.... well.... Clamp!
Now, here comes the part that completely gets overlooked by most people for some reason.....it's actually VERY beneficial for the clamp to flex a little bit. It's a good thing that you would want to happen! The reason I mention this, is especially for new sharpeners or people with a "heavy hand" when sharpening. If you use too much force and there is no "give" or flex to compensate for your excessive sharpening force, then you will end up damaging your very fragile edge - especially towards the end of your sharpening when you do the refinement of your edge. If your clamp has some flex to it and you use more force than necessary, then the knife deflects downwards and you end up very slightly convexing the edge or grinding away metal just behind the edge - not necessary a bad thing and the clamp then saves your bacon when you have a heavy hand....the edge deflects away from the stone because of the flex of the clamp.
Of course, you don't want a clamp to flex so much that it is effectively useless at holding your blade in place like a "slinky" for sharpening, but this is not the case at all with any of these clamps.
Why guys don't "get" that is beyond comprehension. A little bit of flex in a clamp should actually be mentioned as a "positive" rather than a "negative". But I guess that's what happens if one likes making Youtube review videos, hearing oneself talk and thriving on thumbs-ups or "likes", more than actually learning as much as possible about your hobby or passion. Sorry, I digress...
It's kind akin to hand sharpening where you apex your edge nicely and progress through your stones, only to loose concentration at the very end and raising the blade spine too much...you can ruin your edge in one foul stroke. If you make a mistake at the end of your hand sharpening and actually
lower the spine of your blade, lowering the sharpening angle for one or two stokes when you loose concentration, your edge will not be affected. That's basically what the flex in these clamps do for you.
Hope this helps clear it up?
