I wouldn't use oil that can go rancid or rot but if it works for you....I use coconut oil because it’s food safe and it hasn’t given me any problems, and kept the rust off my carbon nicely![]()
Why not?I really don't want to buy special oil for my knifes.
Well, since it is essentially food, it will mold and or go bad at some point. How that could hurt you or your knives, I don't know as I've never tried! If you keep it clean and reapply that often and it seems to be working, maybe no change is needed. For something food safe and that won't go bad, try mineral oil.What will happen? Admitted ignorance. I use it because it’s what I have and it’s food safe. I never even considered that it has an expiration date.
Side note: I keep it very clean, wash it out and reapply every day, or maybe two if I’m busy.
Cool beans!For the amount of scratch I spent on my blades one $10 bottle of oil ain't going to kill me.
Some household/industrial oils will leave a residue, which is kinda what they are designed for and could be a good thing if you don't handle your blades often.
The bad thing is I wouldn't want to cut an apple with that knife and then eat the apple. Not unless you want to risk some Hershey Squirts.
Just give it up and buy the good stuff.
You can absolutely use any cooking/salad oil you have around, BUT.... : most of them will get sticky, rancid or even corrosive over time. Not a big deal for one or several often used knives. I used olive oil for years to prevent corrosion on (frequently used) carbon steel blades. Now that I have so many knives that I can't use them all frequently, I switched over to Camelia oil (tea seed oil). It's food safe, neutral, stable and very affordable. With a small drop, the most sensitive carbon steel blades stay pristine unused for months. What is there not to like ? Short answer : get a specialized oil. Grease from the hub won't do the trick.
