Munk Chunk Cleaver?
can i put you down for $10???
then so far, you and i are the only donators...and the total is up to :
$20.....
after the tests, i'll explain why i think a 12" model is a good choice to test.
it's in usps' hands right now.
Yes,
I have not read this whole thread. There was another forum member that IIRC pleged $50 when I brought this up several months back. I'll see if Ican find that thread.....
Are you planing on doing a 12 incher or a 15 inch Chiruwa AK? I truly believe we need an 15 or 18 inch CAK. A 12 incher is not going to cut it.
I don't know what all the wining is about! "don't hurt/break the khuk" Everything sould be tested to failure......cars, guns, electronics, knives, everything!
I can't wait to see the test....BRING IT ON!!!!!!
I'm sue I remember reading about someone testing a knife by chopping up concrete blocks and cutting thru a couple of old car bodies a couple of years back. Since the only forum I tend to check on is this one, I always thought it was an HI Kuk, but guess i could be wrong. Can't use search function here any longer, and in any event it seems the old posts have been archived elsewhere. Isn't there some other "old guard" who can settle this one way or the other?
i was thinking of sending in a standard 15"-16" CAK......
if none are available, i think a 15"-16" tin chirra would be a great substitute....
tin chirras have nice thick blades with a chiruwa handle....only difference is that a tin chirra has one more fuller in the blade than an AK.....
and to answer your question, magnum is sending in a 12" standard handled AK....
Munk Chunk Cleaver?
Be interesting to see how it holds up against the Cold Steel Machete.
I'm pretty sure I could go outside with any of my HI khuks and chop my Cold Steel Khuk in half.
I play with the MCC here:
http://www.bladeforums.com/forums/showthread.php?t=449251&highlight=Munk
And here is a link to the best HI Khurk (IMO):
http://www.bladeforums.com/forums/showthread.php?t=513567&highlight=Munk
