- Dec 27, 2010
Great project, I'm looking forward to seeing more updates. I hadn't heard of the CA finish before; always nice to learn something new.
Patrice Lemée;11937101 said:Karda, that is a very interesting point I had not considered.
The thing is, this will not be epoxied, it's a take-down. There are no alignment pins int the centered spacer but it is a pretty tight fit. Would loosening the fit a bit help?
It is still pretty tightly held between the wood and the bone so I could probably loosen the fit by a few thou but not sure it would be enough. I will sharpen it tomorrow and put it together so I can cut a few 2X4. I will post the results and how it felt.
I appreciate your input and the good words.
PS: Sorry, posted without seeing your edit.
Patrice Lemée;11939276 said:Karda, while I have you here, let me pick your brains about that large ring. I included it in the design because you see it in almost all traditional Khukuris. I wonder for a long time about it's use. The only plausible explanation I a came up with is that it makes you grab the handle with your first 2 fingers, keeping a looser grip with the last two and that this is much better for hard chopping.
Am I even remotely close?
I would really like to keep it as is since not much else on this one is traditional.
Thanks for your help.
From the Khukuri FAQ said:Handle rings - traditionally-made khukuris usually have a number of rings carved in the centre of the handle
"Kami Sherpa thinks the rings and little ridge once had a definite meaning of some kind -- almost certainly to do with religion -- but he says today nobody really knows what the meaning is or was. He points out that the configuration is fairly rigid. A pair of rings down maybe 1/4 of the handle length from the bolster -- small space and another pair of rings -- then the ridge with a single ring in it -- a final ring just below the ridge. Personally, I find it very interesting that almost all good kamis use the same configuration but none of them know why they put it on the handle or what it might mean". -Bill Martino
Patrice Lemée;11942199 said:Nathan, I am dying by application or immersion, and it has more to do with how the bone absorbs the dye so not sure airbrushing would work any different. I am playing with texture and it's weird, a rougher texture seems to give a more uniform absorption and a finer finish, a more blotchy one.
I appreciate the suggestion, thanks.
