That's alright. This is one of those instances where you don't know...how much you don't know. Many here have done it, myself included.
With the 302UF, for the past days ive been (trying to) polish my Techno, the blade faces of it not the blade bevel. Originally the blade has a "stonewashed mirror" finish, basically a mirror finish which got stonewashed for christ's sake. I am still at it and it's going well. Now i am noticing that the stone surface isn't dull/matt (with the infamous pronounced machining ripples) anymore but has become shiny, i.e. pretty much reflective. Crazy. I mean, i can't see my face reflecting in the white stone but i can see a rather clear and sharp reflection of the business end of my Olight headlamp — these cold dark short winter days i wear a headlamp during my desktop work. And interestingly (but as to be expected) i can see the Spyderco machining marks now more clearly than ever .. like defects in a mirror finish; even though the ripples' height is less pronounced.
Turning a flat smooth surface from matt finish into shiny-reflective finish is an indirect proof of an improved locally flatter (and smoother) finish. I did it, and i'll keep at it because this experience is very motivating yay
: my stone has become a UUF stone!
The four corner areas of the rectangular stone surface are still a bit matt/dull, understandably; i can't go too near while polishing the Techno blade, trying to avoid accidental slip-offs over the sharp corners. It means that i have been dishing out the 302UF stone on a microscopic scale, that's fine
. It would be interesting to learn if
i could make the "defects" (=Spyderco machining marks) completely disappear from the new
reflective (in a sense 'mirror-like') stone finish. I could go visit manufacturers of marble sill tiles, they know how to mirror-polish marble still tiles. Then again, marble is much much much softer than the Spyerderco UF stone, so their lapping method might not work on the superhard 302UF; and btw lapping the 302UF to 'marble sill tile'-like mirror finish can't be as easy as what those marble manufacturers do .. otherwise
@Sal Glesser would have done so and we wouldn't have all those massive machining marks and "non-perfect-flatness"! You're asking, why not use a "mirror polished" superflat stone from the get-go, like my Anself GREEN10000 and WHITE10000 ("Natural Agate, Emerald, White Gem"), instead of the 302UF? Because these natural stones are for mirror-polishing only and not suitable for sharpening: they don't have cutting power/properties like a ceramic stone, and with (accidentally) raised pressure and angle you'd scrape into the mirror finish, pulverizing the stone material at that spot. Look at the blade bevel and you'd see stone powder produced by your scraping bevel. While it is possible to raise a burr with those natural stones, they set you up for failure and eventual stone damage. Steer clear of buying/using/lapping such mirror-finished natural stones other than for polishing.
Back to the 302UF stone. While I do believe that lapping with an Atoma, with SiC powder (or with another 302UF stone, for that matter!) will eventually produce a superflat homogeneous ceramic stone surface, i highly doubt that such a produced surface could be called a 'UUF stone' as mine
. The next question in line would be, what's more important: an improved-mean superflat stone (of unspecified smoothness) or an improved-ultraultrafine ceramic stone?
Long post short. Just imagine a Spyderco UF stone with the mirror finish of a marble sill tile! A 2292 dream come true
