- Feb 27, 2013
I reluctantly took on the challenge of designing and machining a full back spacer for the Inkosi given that this model knife did not employ a lanyard pin to fix the rotation moment of said spacer. Lacking a lanyard pin it was necessary to design the back spacer to utilize the blade stop pin and capture a sufficient degree of the stop pin diameter for the required fixation of the potential rotating moment. That said... the tolerances are so exacting with CRK knives I doubted my ability to make it work.
Surprisingly the first machined prototype function perfectly...! With this success I went back to the original design and made some slight dimension adjustments to make a more robust forward capture cusp.
I've drawn up two profiles in CAD... a smooth spine and heel and a cogged spine and heel. Both are low profile and have chamfered edges.
I machined both the cogged and smooth versions out orange G10 and here are a few shots of the cogged and smooth back spacers installed in the knife.
