Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
I voted S7. Of the listed steels it has the lowest carbon content (0.5%) and is therefore the least likely to break/chip, all other things being equal. Using the toughest possible steel allows me to use thinner stock (less weight, better geometry) in a designated survival knife with relative confidence. I plan to chop dry wood with my survival knife, and I may not always have the best technique if I’m freezing, so toughness is a high priority.
Luckily you don’t have to…I can't do this.
I dare you to go out back or anywhere else that has a tree. Using those teeth to cut a 1" or bigger tree branch.
Going up to 4 inches. The big logs in the fire.
That's Rambo movie inspired.
I probably wouldn’t have considered it but for the fact that the steel is S7 (mod).The problem with very much most of sawback knives is that it is exactly there where they will fail under stress. I see the slightest of radius at the bottom of of those particular saw teeth (or perhaps they are more intended as a rasp - like on the later Glock field knife), but generally they are a very bad idea. (Like any structural engineer might tell you that windows in a building are designed failure points...true, but practibility has also be considered...)
However I have, and while it’s certainly no match for my Silky saws in efficiency, due to the full-flat grind, pull-action, and relatively thin stock, it actually saws wood pretty well. I wouldn’t use it for fire making, but it would certainly come in handy for shelter building…
I know that the vast majority of saw backs are basically worthless, but this is the exception that proves the rule…
Quite possibly - but that’s ok with me.![]()
A sawback on a blade has only one purpose, and it has nothing to do with wilderness survival....I know that the vast majority of saw backs are basically worthless, but this is the exception that proves the rule…
Actually Busse put out a video demonstrating that unlike most saw-back knives (even the other models they make) this one was actually designed to SAW WOOD.I think Busse says they’re actually for notching and not intended to replace a saw. Which is more ammunition against them IMO. Their presence verily likely increases the risk of a failure with a stress riser.
Fair enough, I somehow missed that video from them. SR-77 has always treated me well.Actually Busse put out a video demonstrating that unlike most saw-back knives (even the other models they make) this one was actually designed to SAW WOOD.
Yes re:stress risers, but this is for wilderness survival rather than urban survival/war. I won’t be chopping/prying cinder blocks, so (with S7) I’m pretty confident.![]()
This seems logical , but is highly misleading . Contrary to many real life events .If you're ever in the situation. You're going to treat your knife like your life depended on it.
It'll be used but extra care, it will be taken care of. It has to last you and do it's job. But only if you take care of it.
Otherwise, it's a ridiculous JoeX.
