- Sep 4, 2011
#NotNathanInteresting question. HopefullyNathan the Machinist can chime in and clarify any changes to the fore-end of the handle.
Sounds like it'll be a little bit different don't know if it will be a problem with the changes for a leather sheath
"There are some updates with the new release of this classic pattern. Compared to the original Shiv, there is the thumb ramp jimping and deep chamfers we have become known for (these are found on some of the later production OG Shivs). The finger guard is a little bigger. The heat treat is now our fully optimized Delta Heat Treat (an early version of this was also found on the last few OG Shivs to leave the shop, though they were un-marked.) The hand grip has been tweaked a little. The primary grind has been narrowed a hair and the fuller has been adjusted to compensate (I'm keeping the weight and balance roughly the same through the distribution of material and the sectional modulus is basically unchanged). I'm stretching the point out 1/2" to give it a full 8" edge length rather than 8" tip to scale. "
