On thick knives in particular I find a strop to be helpful for cleaning up the big bevel so I can see how much more work I need to do with the stones.
It also does a good job of deburring before I set the final edge. I know that isn't quite the way that most people talk about using strops but I tend to like the crisp edge from stones.
I will strop the kitchen steel if I just want a quick touch up. I load my strops with fairly coarse compound (about 500 grit) so it doesn't take too many passes to clean things up.
Bumping this post for the good doctor.
Also, if you had one strop for the rest of your life, what would it be?
Folks have been using sand paper for a long time to sharpen their blades.. hard backed for v edge and over a mouse pad or sheets like the video for a convex edge...In terms of sharpening I am really new and not good at all. So i use a work sharp field sharpener that I am able to get a decent working edge on my knives with that can shave hair, but I wouldn't say with "ease".
However I came across this video where someone uses Trizact 3M sandpaper and it acts as sharpening stone/strop all in one.
Seems like an amazing, simple, cheap, to good to be true find!
Who knows....
I've ordered some to try it out
Check out the video on it
https://youtu.be/yK__FD1nfbY
Someone who knows how to post the video directly on the thread, feel free to do so!
Its not a stone and strop in one...you have to use it edge trailing like when stropping thou otherwise it'll cut into the sheets when it's on a soft backing.
You still gotta strop for better results just like off a stone.
Sent from my SM-G935V using Tapatalk
The cool dudes around here got me introduced to emery cloth. I got some from a local hardware store.I ran across somebody that packed emery cloth for emergency sharpening.
It doesn't crinkle up and tear the way that sandpaper will so it is more durable.
I use Flex Strops (they also go by Flexxx Strops). They offer double sided ones in different sizes with black, green and white compound already preloaded (you get a choice of two compounds for a double sides strop you purchase with black being their grittiest and white their least gritty --- I've forgotten the microns). I have not heard negative comments about the quality of their products but one constant complaint (which I happen to agree with) is that they are kind of stingy with the amount of preloaded compound for their prices. That said, they use BRKT compounds and it will be worthwhile to buy some bars of BRKT compound as you wish to get good at stropping.
That Work Sharp "strop" leather piece is rubbish Mate!
Can anyone recommend a decent strop? I have been using my work sharp field sharpener and it is great, but i am not to fond of its strop + it is tiny.
