Jiki
- Jun 12, 2018
10 or 11 if memory serves.Do you happen to know how many special assembly Pocket Carvers were made, by any chance?
Contact GEC they will lead you in the right direction and fix the knife I’m for ya.This was initially posted in the GEC #73 Scout Trapper thread, but might be more of a general GEC question:
I bought a 2021 #73 Rosewood Trapper and a 2021 Remington Prospector Baby Bullet, both new. Both knives were supposed to be users / EDC, but both developed some horizontal blade play. The sketch shows the Remington Prospector as seen from the front: The blades and liners slipped against each other. This makes me think that maybe the pivot wasn't riveted tight enough in both cases.
The knives were not mistreated; the worst I did was using the spey blades for spreading cold butter on some buns.
I sold the knives with a large discount. Right now I'm eyeing another (older) GEC Trapper. But before I fork out some more money, I'd like to know, have I been just unlucky, or is this a known issue with GEC knives with two blades? (Like vertical blade play with the earlier backlock knives).
I'm based in Germany. Considering the cost and paperwork of sending knives across the pond, I didn't bother. If the GEC-experts here should tell me that blade play isn't an issue with double bladed knives, then I'd try my luck on the other knife I've got my eyes on. If, on the other hand, blade play was a known issue, then I'd give it a break.Contact GEC they will lead you in the right direction and fix the knife I’m for ya.
I sold the knives with a large discount. Right now I'm eyeing another (older) GEC Trapper. But before I fork out some more money, I'd like to know, have I been just unlucky, or is this a known issue with GEC knives with two blades? (Like vertical blade play with the earlier backlock knives). I'm EDC rotating some #74 Mustangs and a #15 Urban Jack, and couldn't be more satisfied.
I have a similar problem as you.I'm based in Germany. Considering the cost and paperwork of sending knives across the pond, I didn't bother. If the GEC-experts here should tell me that blade play isn't an issue with double bladed knives, then I'd try my luck on the other knife I've got my eyes on. If, on the other hand, blade play was a known issue, then I'd give it a break.
This is absolutely true but outweighing the pro and cons before deciding is tedious especially when I have had no experience with blade-play before now. I can't tell what should be tolerable and what shouldn't.I guess the blade play is up to the owner and what they are willing to put up with.
I thought of doing it myself JoKr but I am afraid that the pivots pin will protrude ever so slightly from the bolster and thus be visible... Anyone with experience, tips and tricks?
More mojo. We need all you can throw out there. I feel so close to finally trying a 77Throwing a little 77 mojo out there....
If you use the search function. In this forum you will have the answer in seconds.Try as I might, I have not been able to find anything about why the #65 is dubbed the "Ben Hogan." Could anyone provide some illumination on this? Thanks!
You're quite right. I had used the Google to no avail, but somehow neglected to run a search here. My bad -- apologies.If you use the search function. In this forum you will have the answer in seconds.
No apologies needed. Teach a man to fish.You're quite right. I had used the Google to no avail, but somehow neglected to run a search here. My bad -- apologies.
sorry to just jump in here, but, that is what you want, when you squeeze everything back together... a slight protrusion will allow you to peen it down, which flares it out to "seal" the pin hole, and tightens the assembly up. Once you have peened both sides to as tight as you want them, then simply file, or sandpaper down the top of the pin to be flush with the surface of the bolster...... then polish to whatever finish you desire.I thought of doing it myself JoKr but I am afraid that the pivots pin will protrude ever so slightly from the bolster and thus be visible... Anyone with experience, tips and tricks?
