This post is a lesson in old machinery HP requirements and specs.
In moving my hammer rather than having the motor hanging off the side and running to a jackshaft bolted to the frame and suspended above the hammer, I wanted to simplify things and make them more like the original motor powered configuration, with the motor and idler arm behind the hammer. It has been running fine for years with a 2hp 1725 rpm motor.
The original spec called for 350 BPM, driven by a 900 RPM motor. 900 RPM motors are getting few and far between these days, because all the extra windings for slow speed cost a lot more money to make, but I found myself a huge baldor 2hp 900rpm motor. The original design for the motor driven hammers was just direct drive, motor to hammer with the tension arm and idler attached to the treadle. The drive pulley on the hammer is 13 inches, so I needed a 5 inch drive pulley for my motor. I made myself a crowned drive pulley, fabricated a new motor mount, got a new belt, and just yesterday fabricated the new tension / idle arm and linkage.
Everything looks like it should work just great, right? ... Not quite...
Here's a look at how the hammer was originally set up with the 2hp motor that I was using. Take careful note of what I have eliminated...
I removed more than 60 pounds of rotating weight, and the result is that the innertial energy stored in the top shaft as a flywheel effect is gone. When I step on the treadle, if I step hard, it just stops the motor dead, if I step slowly it will start hammer moving and then pick up speed and I can step down harder, and it works fine. The old literature gives weights of the hammer with and without motor, and as a result. The originally fitted motor for this machine weighed almost FIVE HUNDRED POUNDS, so even though the horse power rating is the same, it weighed 5 times as much as the motor I've got on it now, and had effectively several hundred pounds more rotating mass, it was it's own flywheel. In talking with another owner of a slack belt clutch Fairbanks power hammer, he said he obtained his with a 5hp motor, and it would do the same as mine is doing right now, bog down and stall the motor if he stepped down on the treadle hard from a stop. He instead ran a line shaft with several large heavy pulleys off of a 3hp motor, and it now runs great, and picks up instantly. Even though the literature says "2hp" needed to run the hammer, the old machine literature is talking about line shaft HP, and those line shafts have a huge amount of stored energy in them which allows that energy to transfer into the stopped hammer for the initial lift needed to pick up the 100+ pound head and start the two massive discs on the hammer spinning. The real lesson here is that the rated HP to run a machine does not necessarily equate to the power needed to START that machine. Modern technology is wonderful, but there were some distinct advantages to the old lineshafts, and ginormous motors.
As much as I wanted to simplify things and get away from having jackshafts and whatnot... it looks like I'm going to have to build a shaft system with some mass just to store the energy needed for the initial start of the hammer. This design has been recommended to me, just throwing a heavy flywheel on the back of the shaft opposite the drive pulley, just like on Mike's model A. I should be able to keep using the same 900rpm 2hp motor which I purchased, and the pulley which I made, but I'm going to have to hit mcmaster or something up and buy myself some 1 1/8 shafting, some pillow blocks, and some V belts and fabricate a shaft which I can drive at a 1:1 ratio with a pair of 4 inch double V pulleys that I already own.
I just ordered parts from McMaster to build a new jackshaft similar to the one pictured above on Mike's machine. I also have a 50lb flywheel which will fit on the end of the jackshaft that I can add to give it some real momentum. The shaft will be 1.125 to match the pulley I made, and the 4 inch double Vbelt pulleys I already own, so I can drive the shaft 1:1, the flywheel has an inner diameter of 1.165 so I may have to slip some 20thou shim stock in it before I tighten down the set screws. It's an old 22inch diameter 3 step pulley from a treadle lathe, which made its way into my house while I was restoring an 1880s barnes velocipede lathe. It wasnt the right size shaft size for the lathe, but I'm glad I held onto it now. I know it's good at 300rpm, but I'll have to be careful and see if it's still good at 900 rpm
