- Jun 13, 2007
Very good, thanks. I still have one stop at Hobby Lobby to grab a set of overstitch wheels, but the sheath is getting closer.
Well done! Don't beat yourself up 'cause that's a nice job. It's the same with knives, the maker always sees little things that anyone else might never notice. I'm a big fan of that green dye job, too!
Haven't tried it myself, but I've read you can mix up leather dust with some contact cement, fill in gouges with it and sand everything flush. It should be a dry mix, more leather dust than glue, so it can take dye and finish.
I dislike the welt edge. There are a couple of small gaps, and the only thing I can think of is that the welt must not have been skived evenly. I did sand it after skiving, but apparently I didn't make it perfectly flat?
Sky, if you're reading this, I decided to burnish the edge using beeswax. Is it possible to fill those gaps somehow? I was thinking about melting a little bit of the wax into the gaps.
That's great job for the first one, Alot of people would love to see colors like that on a sheath! To fix the edge you don't really want to try and fill it with something, rather just sand it down some more until you have it flat, same way you would work out a chip in a knife edge. Once you've done that rub the edge with tandys super snot and wait for it to dry then burnish it with beeswax. I don't really recommend super sheen or atom wax because they tend to leave spots when you get them wet. Either Obenaufs or grab a jar of sno-seal for a couple bucks.
After reading this thread for a while, I had to make a go at this. I went a different direction from the pouch sheath. I took one of Tal's designs for a nessmuk I liked and and tried to copy it. I had only seen the first video by the time I made the sheath, so I will have to watch the rest of the videos and see what I missed out on. I think I can agree with many of the posts here - it was very much a learning process and I would not do some of the same things again. I made a bunch of mistakes that are very obvious to me, but for a first learning attempt I think it came out OK. I pressed too hard when wet forming. I need a depth stop on the drill press when the needle punched through, because it touched the leather several times. It took me a while to figure out to drill a hole in piece of wood just larger than the needle and use it as backing to give the sheath enough support so that the needle would make a clean straight punch. There has got to be an easier way to connect the dots on the back than the adjustable v-gouge. I over ran the groove in a couple of places doing this. The list goes on and on. I certainly have a huge appreciation for the sheathmaker's work I see here. This was definitely a fun project and I will try to make some of my own sheaths in future. I figure I need about 3 more before I break even on all the stuff I bought to make them... and sorry for the crappy pics, but here it is:
Thanks bud.
I think that, instead of grabbing an off the shelf item, I'll try my hand at making my own conditioning/protectant. I've got plenty of beeswax and also a lot of coconut oil (we use it for a lot of baby products we make) and I think those two will emulsify fine since no water is involved.
Edit- okay, I made some conditioner going by a recipe online. I applied it to the sheath and really like the results. Much less shiny than the Super Sheen. I haven't tested water resistance, but will eventually.
Here's a final wet formed and "sealed" pic. Notice how shiny the dangler is compared to the sheath. Too bad I didn't know to do this before doing the dangler, but it's all about the learning on this one. Again, many thanks!
M4 I really really like the two you've made. Imo they are definitely some of the best ones in this thread. I'm starting on a sheath for my standard Karda, and I'd like to do one similar to the first one you did.
My questions are simple, and Tal (or anyone else), you're welcome to give input as the design was influenced by your work. My question regards the welt and depth that the knife sits at. On a sheath like this, is there one layer thickness of welt? Is it skived (tapered) toward the bottom, or left full thickness? On a ratio, how much of the handle sticks up out of the sheath? On my pouch I have about 1/3rd of the handle outside of the sheath.
My goal on this one is to keep the wet molding for retention to a minimum. I also plan to basket weave tool the front but I may chicken out.
Thanks for any advice,
Anthony
On that style I use 1 welt plus a skived wedge welt about 1/3 the length on the top, makes it so you can get the handle in easier. How much handle sticking out is just personal preference.
I just draw. Alot. Imagination is pretty much unlimited.
Cali is a pain. My solution to their millions of ignorant laws is easy, I just don't bother following their laws when I'm there.
Anthony
Your days of buying them are over.
TF
Strig.
Do you want my designs? What knife are you working on? Tell me what you want to do and I can try to sketch something up.
You know? That is really what is missing from my thread - a design video. Should we do one?
TF
