Mirror polish vs toothy edge?
A somewhat toothy edge is the way to go for me, for sure.
But im a hunter and outdoors man. If i was into something else it might be different.
Also, i dont have the time to maintain a mirror edge as of now.
Finely polished edge, no question. It may get "toothy" to the customers's liking over time. Great ! But no knife leaves my bench without a razor polish finish. Even if it's just my pleasure...
For K390 i don't, it's been tempered at 550c 1022 f and I slow my belt down significantly. occasional dips in water and light passes should do the rest.
I heard some say that a faster belt is actually better. I have a WSKOBGA that I sharpen some knives on but I use my
WE-130 for all reprofiling and most sharpening.
I liked either way, if i want it to look good, i add a mirror polished edge just for fun and giggles. But for my every day uses, both are adequate. Although, it much more painful to repair a dinged polished edge... you know redo the stones succession and lapping all over again
I notice that a mirror polished edge has trouble starting to slice a tomato. Toothy is best for tomatoes. Also cutting rope is less easy with a mirror edge. I'm of the opinion that toothy is best for slice-cutting and mirror for push-cutting. So maybe different edge finishing for different blades in the same knife. A great reason for a multi-blade pocket knife!
  • Like
Reactions: DMG
I never worked with either of the sharpening systems. I mostly try to put on convex edges.
Depends on the blade steel.
I read in one of @Larrin 's articles that some steels, such as S30V, perform better, and hold an edge longer with a "toothy" edge, than a highly polished one. Other steels (I think he said D2 is one) do better with a highly polished edge.
My "finest" stone/hone/plate is a "600 grit" diamond plate. To date, I haven't "needed" anything finer.
Disclosure: I have no idea what "grit" my old "Soft", "Medium", and "Hard" Arkansas stones I had between circa 1961 and 2015 were. The "Medium" and "Hard" might have been finer than "600 grit", but I don't know if they were.
Arkansas stones cannot be measured, and should only be loosely compared, to grit ratings. "Hard" is roughly about 900-1200. Medium about 600-800. The reason for the ranges is that they both cut and polish at the same time, plus they vary a little from stone to stone, plus you can lap them to specific points in the range. So it's hard to compare.
I only put convex edges on kitchen knives. I like my main knives flat ground in case I'm somewhere and all I have is a freehand stone.
Ah, one of my reasons for convex is that I naturally put them on with freehand stones. operators bias I suppose...
That being said, the jury is still out on the knives that I make. Most of the people who got a knife from me aren't expert knife people so I make and design them on theoretical principles and my own experience so far.
One way I sharpen my knives is by hand to a 15° per side primary edge on diamond plates, usually 320 grit, followed by 600, and once it is apexed, I do a few light passes on the gray colored Spyderco "brown" rods for the SharpMaker at 20° per side for some toothy microbevel action. The other way is I eyeball approximately 15° per side on the grinder using 120 grit ceramic belts, followed by 240 grit, then refined on the fine scotchbrite belt. I do this on either the platen or the slack portion of the belt, depending on the knife. After that I still microbevel to 20° as aforementioned. I usually strop also on a leather hanging strop. These edges are toothy, but smooth and quite sharp. They get the job done.
Doesn't the stropping remove or diminish the toothyness?
As Rhinoknives1 said, Stay Safe!
My Pal “Horsewright” added what I didn’t put in my post to the OP, besides removing the burr, polishing/Stropping with Green Chrome Compound , it polishes the apex of the edge so you has an area to start your initial cut with the teeth at the heel of the edge to follow on a draw cut!
Big advocate of a toothy edge. Every knife I ship has one. Just cuts real life stuff in the ranching world better. Try cutting a calf with a polished edge. Slides all over the place without cutting. Ask me how I know.
This!!
When cutting calves, my edges touched up on a diamond stone cut much better than ones I hage taken up through the medium and fine ceramic sticks and stopped.
Also, tomatoes and other foods cut better with a toothy edge. Bread too.
