Mods, Regrinds, Cerakote, and Sharpening
Thanks again Josh :thumbup:
Glad to do it! Hope they serve you well =)
___________________________________________
Here's a Liong Mah SDC I finished up last week... double hollow ground w/ contoured scales. Here's a before factory image and you can see the difference =)
Looks Stellar, can't wait to get it. Liked the ergos and action of the Chaves but not a fan of a lot of belly. REK fixed that for me and added some color too..
I got my XM-24 back from Josh last week. He reground my XM-24 Spanto into a Spearpoint with a hollow primary grind and recurve with a 220 grit finish. The liner, lockside, pocket clip, and spacer were cerakoted in flat black. Thanks Josh I will definitely be using your service again.
Hope you have gotten to use it Greg! Great color combo you chose there!
Josh, the Liong Mah SDC turned out awesome! Thank you. I am loving it now.
Thanks man, nice call on the elongated swedge! I think it turned out great =)
Dude thanks for the assembled pics! Since I only got the blade and parts I wasn't sure how it would all look back together - looks sweet!
Man I'm gonna have to hit you up when you do DLC. Gough customs has a video on YouTube and cerakote and DLC did the best and DLC blew cerakote out if the water!!!
Just finished a few up recently!
Here's a Busse Basic 8 that I dropped the point and rounded the spine, then added a dip for a rest for the thumb but also a great place to scrap branches with.
Reground this SNG and gave it a 'muted' tiger stripe pattern
ZT 0562 reground to a bowie configuration w/ a swedge then an ESW over top
Strider SNG drop point: converted to a wharncliffe and blacked out w/ Cerakote
Hinderer xm18 bowie given a compound grind at 120 grit
Josh at Razor Edge gave me the coolest ZT560 Blem in existence! :D
Also, he is very nice and patient. He took his time explaining stuff to me. I will be back!
Thank you.
Here's a little of what I've been up to recently!
Strider PT shortened and converted to a santoku sheepsfoot grind, then bead blasted
Hinderer XM18 wharncliffe reground to 60 grit
Here's a Hinderer XM18: here's an interesting one... started off at a spearpoint/spanto which I added serrations. Then I got it back in for a full compound grind and a subtle harpoon swedge mod, then gave it a working finish after everything was done!
Grayman SATU, reground to 60 grit and removed recurve, sculpted the scales and added a finger choil, then bead blasted the scales
Finally I got this pm2 in that needed a mirror polish at 15 dps =)
This was a fun one... Added a choil, extended swedge to the tip, and gave it a slicer grind w/ a long sweeping plunge
Just got my Bradford G3F back from Josh and he did a fantastic job on the regrind. He's my go to guy from now on.
Incredible!!!'
finally got a sort of blackwash figured out... still have to perfect my technique though. Looks sick!
Emerson CQC-10, reground and raised grind height, converted to a thinned out V edge at 15 dps, rounded some of the angles on the scales and added a thumb ramp, then Cerakoted the liners in a Carolina blue and the blade in a flat black.
