OK, I've been thinking about this way too much... I don't think it would slice all that well with just a double hollow. The edge needs to be thinned as much as possible to reduce resistance.
The red dashed lines are the original profile above.
I really think it should be flat ground first - shown by the green dashed lines.
Then, do the hollow grind & give it just enough concavity (.3mm) to not stick.
What do you think? Is this something you can try? I'd do it in a heartbeat if I had access to a big wheel. Right now, a 10 inch is the biggest I have.
