Fortunately, in the room I'm sitting in while typing on the laptop, I have a Sharpmaker set up pretty much permanently on a table by the window. So I usually give her collection of Victorinox, Boker or Tramontinas a quick hit on the ceramic when they skate on my thumbnail. (She won't use my "good" kitchen knives from Jerry Halfrich or Murray Carter.)
It's funny that in all these years of reading about you and others using the coffee cup method, I've never actually tried it out. Maybe I'll do that this week for a change of pace.
Blues, it's funny you mentioned Sharpmaker. So as I said earlier, I've used SM for years to handle a variety of jobs, ranging from knives I want to do quick and don't care much about, serrated knives, etc. I've gotten aftermarket stones from Congress tools (SiC stones) that cut really fast and let you reprofile blades to 15 dps *many times* faster on SM than with their ceramics or diamond stones. Honestly it's still a great tool for all those jobs that for any reason, I don't want to freehand.
I was curious about this new sharpener because it was (a) within reach of the average person, cost-wise, and (b) was a more interesting design than I've seen on most lower priced sharpeners. So I wanted to test it out to see if it could surpass Sharpmaker. It did do a pretty good job on reprofiling my Spyderco, as I said in thread.
But after using it a few days...it is not very versatile. I still think ultimately, Sharpmaker is a better, more powerful tool, even though limited to only 2 sharpening angles. I returned the Worksharp. Sharpmaker is still my go-to for all non-freehand jobs.
ETA, the main reasons why I still prefer Sharpmaker in the end:
* Availability of more sharpening media. You can go to
Congress Tools and get a variety of 3rd party, 1/2" x 6" triangle stones that fit SM, in addition to the diamond, CBN, and ceramics you can get for it.
* Not limited by blade width. While SM has only 2 angles --15 dps and 20 dps--it is not limited by blade width as the clamp-based Worksharp is. Worksharp simply can't handle narrow blades unless you're willing to go with a higher angle for your edge.
* Inconsistency in the strokes due to the sharpening block design. Often, depending on the type of steel in the blade, the sharpening block sort of "sticks" or "hangs" as you're making a stroke, causing it to rock or tip, which then grinds uneven spots into your blade. This varies a lot by steel, and while you can alter the pressure to reduce the problem, and you can improve your skill at using it, it still occurs. In the end, I think this sharpening block is overcome by the laws of physics. It's just too small and light to enable a consistent smooth stroke across any blade.
