Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
It's just me. I have the Edge Pro Apex, (and most of the accoutrements, including the Diamond Matrix hones), and even have it fastened in place alongside my shop sink. It really couldn't be more convenient unless it sharpened the knives automatically and then cleaned itself off.
I think it's just that I somehow find myself disinclined to stand there pushing and pulling the guide rod across the bevel for a certain number of strokes, flip it over and do the same on the other side. Then wipe the blade, the table etc before changing the stone or changing the angle, whatever.
Perhaps its because years ago I scratched the faces of a few blades with it because I was too lazy to tape them up. (These were nice custom blades.)
Mostly it serves as a fall back / fail safe position...in that in the back of my mind I know it's there if I either have difficulty with, or screw up one of the knives freehand, or have a blade that requires putting on a bevel and edge from the get-go because it didn't come from the maker properly done. At least I know that I have a way of making it come out pretty symmetrical.
Bottom line, though, is that I'm probably a poor person to ask. It's just my nature to gravitate to the simpler, less fussy, and more direct methods. Maybe I'm descended from William of Occam (Ockham) or something...or just a Luddite.![]()
I feel the same way about the setup I made. It does everything I need it to do, and allows for a lot of control, esp on DLC coated blades and such where I want to lower the angle as much as possible without digging into the plunge line.
I still prefer to freehand, and unless I have a lot of work I still prefer to just freehand it. The outcome is virtually identical.
Good to know I'm in excellent company.
The difference is probably that your freehand exceeds my freehand. I tend to be a "good enough" kind of guy, and don't mind sweeping some dust under the carpet. Though I can be meticulous on occasions when I feel the knife warrants it.
Thanks for this. I'm new here and pretty new to knives in general, and have been planning to get some sort of sharpening system for Christmas. The Sharpmaker has been at the top of my list until I saw this new one from Worksharp last week. But after reading this, I think I'll probably stick with the Sharpmaker.
I have received my unit - all three stones are glued to the holder. I don't understand how customers are supposed to replace a stone.You have to slide the whole sharpening block off the steel rod, then you can pop the stones out of that block and replace them individually.
Hmm,When I try to take the diamond with a knife, it starts bending. 1.5mm thick ceramic stone will immediately break. I misunderstand something...Tri-brasive™
Hi,^Yup. They're cheap!But if you wanna put anything less than a 15 dps edge on these guys, or any similarly shaped paring knife, the Worksharp sharpener here can't help you. Freehand it is.
Wowbagger I sharpen small slip joints on my KME often with great results. I simply put some masking tape on the scales and clamp down on them in the standard KME jaws because I'm too cheap to buy the penknife jaws. It's a little trick I picked up on Youtube.
Hi,
Can you do this trick with it?
Very interested, I've already printed this lapping film holder and it works great. I did modify the plates that hold the film to be .5mm thicker so I could flatten them on a mirror with some fine grit sandpaper. I've been able to get some near mirror finishes with this system and the psa lapping films down to .3 microns.I'm working on 3D printable upgrade designs for the Precision Adjust. Once done, I'm planning on making them available free like my other designs and upgrades.
I'm already testing a very good candidate for an upgraded clamp - the very affordable KakBritva aluminum clamps. I'm designing a 3D printable clamp bar with magnetic mount to change out with the original Precision Adjust clamp.
You simply screw the aluminum KakBritva clamps onto it, position them where you want them and swap my magnetic mount bar out with the original Precision adjust magnetic clamp unit. Easy as that.
This will likely allow sharpening angles down to about 13 degrees per side for a blade the size of a Victorinox main blade.
I'm also working on upgrades to be able to use a standard 6mm sharpening rod with printable clamps so you can easily use most edge pro type stones with it.
Those interested, let me know.
Stand by for updates if there is enough interest...
