Here is a brief article that I wrote on the new Wicked Edge WE66 Obsidian sharpening system. I hope that yall like it.
The new Wicked Edge WE66 Obsidian is here and she’s a beauty!
As you can see in the photo, the Wicked Edge WE66 Obsidian comes in obsidian black. I love the obsidian black color on the sharpener. The WE66 Obsidian sharpener came assembled and packaged well with two sets of stones; 200/600 grit stones, and 800/1000 grit stones. It also came with a vise key, depth key, alignment guide, practice knife, 8.75” guide rods, 2 ball joint shields, six o-rings, c-clamp, package of paperboard shims, a card with the QR code and URL so you can go online for WE66 instructions, and a nice Wicked Edge sticker.
In the photos I already have the ball joint shields installed on the guide rods using four of the supplied six o-rings.
The Wicked Edge WE66 Obsidian sharpener comes with the DualCam© vise and Micro Angle-Drive© slides. The Micro Angle-Drive ½”-16 standard thread adjustment screws are as smooth as butter with hardly any noticeable backlash.
The Wicked Edge WE66 Obsidian is designed to be a great sharpener that is light and compact so it can be used at home or taken with you wherever you go. Using the pre-drilled mounting holes, it can be affixed to a table or work surface with screws or to the aluminum base that you can buy from Wicked Edge. Or you can use the provided c-clamp to clamp it to a table or work surface.
I love the aluminum base that I have my WE66 Obsidian affixed to. It is a very nice base for the Obsidian. It has a special spot for the depth key and cutouts to keep small things in to keep from rolling around and getting lost. I know that I have the sharpener positioned wrong on the aluminum base, but I like it that way.
The WE66 Obsidian sharpener base measures about 9 11/32”L x 2 7/8”W x 29/32”H. The vise stands about 3 3/4” above the base. The Micro Angle-Drive screw knobs are about 10 ¾” end to end.
Above is a photo of the Micro Angle-Drive slide. The WE66 Micro Angle-Drive slide is attached to the Micro Angle-Drive adjustment screw using a nut and two screws that can be seen in the next photo. The Micro Angle-Drive locking thumb screw is a Delrin screw and only locks the angle slide in place.
The guide rod is still held between the Delrin guide rod pivot retention screw and the Delrin guide rod pivot socket as it is on the WE60. Without the guide rods or the plastic balls that come installed from the factory between the pivot retention screw and the pivot socket, the pivot sockets can fall out of the pocket that they fit into.
I put a drop of grease behind my pivot sockets and pushed them into their pockets, and they stay put very well. I’ve turned my WE66 base all around and even dropped one of the slides onto the platform base and the sockets have stayed put.
I like the fact that both sides of the Micro Angle-Drive slides operate independently of each other which facilitates utilizing asymmetrical grinds.
You can see in the photo above how the Micro Angle-Drive slides are attached to the Micro Angle-Drive slide screw using a Micro Angle-Drive slide nut and two screws.
The Micro Angle-Drive screw retainer screw takes a 3/32” hex bit and the Micro Angle-Drive slide nut screws take a 7/64” hex bit. The Micro Angle-Drive screw knob retainer screw takes a 5/64” hex bit.
The slide lifts up about 0.1° when you tighten the thumb screw, but you can alleviate that by snugging the slide down enough to take the play out but loose enough to turn the Micro Angle-Drive easy, then tighten it down good after you have your angle set where you want it. It really hasn't been a problem for me.
