For the submissions made so far...
Height Graph
Weight Graph
Height & Weight Graph Together
Scatter Graph
And now for the mind-numbing statistics...
And a follow-up description sure to make even the toughest man cry for mercy:
Minimum = lowest number on the chart
Maximum = largest number on the chart
Top Ten Cutoff = If we lined everybody up in order and took the first 10.
Bottom Ten Cutoff = If we lined everybody up in order and tool the last 10.
Average = well, duh...
Harmonic mean = the reciprocal of the arithmetic mean of reciprocals.
Trimmean = calculates the mean taken by excluding a percentage of data points from the top and bottom tails of a data set.
Geomean = Returns the geometric mean of an array or range of positive data.
Median = literally the number in the exact middle.
Standard Deviation = a measure of how widely values are dispersed from the average value (the mean).
Variance = variation from the lowest to the highest number
Kurtosis = the relative
peakedness or flatness of a distribution compared with the normal distribution. Positive kurtosis indicates a relatively peaked distribution. Negative kurtosis indicates a relatively flat distribution.
Skewness = The degree of
asymmetry of a distribution around its mean. Positive skewness indicates a distribution with an asymmetric tail extending toward more positive values. Negative skewness indicates a distribution with an asymmetric tail extending toward more negative values.
Mode = Returns the most frequently occurring, or repetitive, value in an array or range of data
