Campbellclanman
Platinum Member
- Mar 10, 2007
Beautiful example Charlie, They just did it good didn't they! Gorgeous Bone, you can look at this all day.
I've always done natural patinas. But for the last few days I've been forcing one with an apple and I did do one round of boiling vinegar. It's coming along and the patina is doing a decent job of hiding some of these Dremel marks. But I do need it to be quite dark.@lithiim not sure you want to try my idea because I'm fairly certain there's alot more knowledgeable then me in this thread,but I had an old hunting knife I found that had a blade in really rough shape,at first I used polishing sandpaper and didn't do to much except showcase how rough it was,so then used it to shave or whittle thousands of pieces trying to make sure the blade rubbed against the wood which gave it alot better look,i then rubbed it over and over against rough moose hide and then some more whittling and bit more over the moose hide,after that i let a patina begin,it was very much appealing to my eyes,but than again it was headed for the waste bin,now my buddies son has it or had it.
I want to see moreView attachment 2922113Case Bradford 1915-1919
Picked up this little lobster, with it's case, at a flea market in Berlin.
Very nice! Tang marked??Picked up this little lobster, with it's case, at a flea market in Berlin.
Nice!Picked up this little lobster, with it's case, at a flea market in Berlin.
Looks good to me!I normally kind of despise forced patina. Never even tried it before. But after being heavily cleaned with a Dremel, this knife needed some makeupAnd if patina can kind of hide this knife's abuse, I'd rather that than taking off steel.
Over the course of a few days, I've stuck each blade into an apple multiple times and did one round of hot vinegar in between. This is the result. I think that maybe this knife would've looked something like this originally had it not been cleaned. They did also take a Dremel to the back springs. So, I may do a mustard patina there.
Blades still look super full. Swedges are still present. This is one fine pocket knife! I need to put a fresh edge on it and put it to work
Its a good cover up, I would use 0000 Grade Steel Wool with mineral oil and give those blades a run over- 0000 grade wont remove too much forced patina, then wipe down and then use it as a Steak Knife, I have a 235120 Linerlock GEC as my Steak knife religiously and the Blade is such a very very dark patina for this use- almost a black blade, that way you will gain a nice honest patina that started off with a little help in the very beginning.I normally kind of despise forced patina. Never even tried it before. But after being heavily cleaned with a Dremel, this knife needed some makeupAnd if patina can kind of hide this knife's abuse, I'd rather that than taking off steel.
I think that knife is stunning, but... it would look better with its age on the blade and Bolsters.Nice! What does the tang stamp say?
If those are the original blades (not tang welded), whoever polished them did a decent job because the transitions at the swedge and tang are not overly rounded and the finish is flat instead of wavy, like you see in a lot of "pristine" knives that have had the snot buffed out of them.
Thank you and that is all sound advice! I did take some 0000 steel wool to the blades after the boiled vinegar. But, it wouldn't hurt to do it again and keep working toward a darker patina!Its a good cover up, I would use 0000 Grade Steel Wool with mineral oil and give those blades a run over- 0000 grade wont remove too much forced patina, then wipe down and then use it as a Steak Knife, I have a 235120 Linerlock GEC as my Steak knife religiously and the Blade is such a very very dark patina for this use- almost a black blade, that way you will gain a nice honest patina that started off with a little help in the very beginning.
Man I love those knives
nothing like your amazing Knives Mike, but thank you mateyReally like Sheffield knives. Thanks for posting these guys![]()
