Since the focus for 2015 seems to be the "Quality", i shall post it here for your visibility.
I just received my new Code 4 Spear Point and I'm beyond disappointed, Cold Steel. You would think the new XHP model would have better quality, but compared to my AUS8A Code 4, the new XHP blade grind is POS. For those who says you can fix it by re-profiling the edge, NO! For the 1000th time mentioned, it's not the cutting edge that is off ground(even though that happens 9 out of 10 times anyways), it is the BLADE STOCK, that is being ground unevenly.
My new XHP Code 4 for example, the blade stock is 3.5mm, but when you look at the blade, edge facing you, the edge looks like there is 2mm on the right side and 1.5mm on the left side relative to the blade stock. Also, the spine area, where the flat meets the curve, instead of a straight line, i get small waves, like the grinder moved deeper in the middle of grinding. The new more wear resistance XHP steel probably magnify this issue even further.
My new XHP American Lawman has very severe off grind as well, where the flat part on the right is 3-4mm longer that the left side towards the tip.
I'm beyond disappointed, considering that all 4 of my new CS knives acquired this month have off grind! Code 4 XHP and Lawman XHP was particularly bad considering that they are my favorite.
These should never have passed QC. Fix them Cold Steel!
