Is the poll hardened?
looks almost like a home job with the ears and facets, maybe started out as some kind of connie. BTW those are norlund style bevels, doesnt mean its a norlund though
The Norlund type bevels would fall in line with my thinking that the "M" axes were manufactured by Mann for other companies as well as Mann manufacturing for Norlund.
http://www.yesteryearstools.com/Yesteryears Tools/Norlund Co..html
This may or may not be hardened, not a rafting pattern, but that is a factory head. The bevels are symmetrical and the stamp is centered on the poll so nothing was cut.
Hardened poll axes were much more common at one time (1930s +/-) to demanding and wholly appreciative buyers that specifically sought versatility and durability but increasingly these 'greater expense' items became exclusive to commercial concerns such as forestry, mining and construction. Judging by the eye wall thickness of your axe and the height of the poll you may well have one of these. Running a file over the poll (does it skate)? or soaking it in vinegar will confirm whether it's hardened or not.
If so, as a carefully and thoughtfully refurbished 'user' there will no modern axe out there that can 'hold a candle' to the ruggedness and utility of it. And by gosh it remains 'ordinary looking'.
Clean 'er up and put 'er back to work!
M4 Construction/Rafting
M5
Norlund (Mann?) with bevels and difference in poll coloring.
Your Jersey could be hardened – test it out with good file. The sketch outlines here show the log splitter as having beveled edges on the poll.
The M4 and the Norlund also have the same wedging system when seen from the top down.
Thanks for the comps. BTW, I have only read a little feedback on the "M" axe's steel stating that it is good steel. How does your's take and hold an edge? Thanks!
Woops,should be a b where the p is
Only have one marked m 31/2 with a circle around it ,flat cheeks and very hard steel holds an edge only good for limbing gets stuck chopping
Looking at the various axe head patterns that were posted today, I saw one ("rafting") that matched an axe I have with a hardened poll. This solves a mystery for me.
"rafting axe: a single bit axe with a short handle and a heavy, extended poll (sometimes with tapered corners resulting in an eight-sided poll) suitable for driving and striking and especially adapted for use on logging rafts."
"raft: a group of logs secured together with chains or cables so they can be floated as a comparatively single unit."
--from YesteryearsTools Glossary http://www.yesteryearstools.com/Yesteryears Tools/Glossary: Axes, Edge Tools, etc..html
