marthinus
- Dec 10, 2006
Hi guys. First of, thanks Ankerson for doing these tests.
Forgive my ignorance on this but I am a bit confused. I have read all the opinions and posts of many when it comes to steels but could never find an answer to the following.
Take two same category steels like the AUS8 and S30V at 58. Now when the cuts are made till one can see edge deformation (loss of edge retention) on these steels are similar. But would the composition of S30V enable it to hold a "working" edge for longer then AUS8 due to its composition?
The reason I ask is in my use (not controlled like a test etc). AUS8 is fine, up until it starts loosing the fine edge. After that it seems to dull much faster then my other edges be it S30V or 154CM (and I try to touch up an edge as soon as possible so it does not get too dull). Therefore it requires more sharpening, more removal of steel and therefore shorter life span (theory wise anyway). Longevity for me is something I like in a knife. If S30V can provide that due to higher wear resistance over AUS8/VG10 I would take it.
Thanks for any answer.
