- Feb 15, 2014
We are glad to inform everyone about this knives that we collaboration with the famous designer Kirby Lambert will be released in the middle of next month.
Specification:
Crossroads (Designed by Kirby Lambert )
Bearings: Double row ceramic ball bearings
Open Length: 8.27”
Blade length: 3.54”
Closed length: 4.72”
Blade thickness: 0.157”
Blade material: Bohler M390
Blade material hardness: 61HRC
Handle material: 6AL4V Titanium
Inlay material: Marbel Carbon Fiber/Carbon Fiber/Green G10
Pivot design : Ti Connector
Weight: 150g/5.29oz
Blade finish: Satin finish
Handel finish: Gray(Bead blast)/Black PVD Coating
Locking:Frame Lock
At here, we would like to share some pictures of this knife with you.(6 Versions in total.)
1.Bead blast handle + Green G10 inlay
2.Black PVD coating handle + Green G10 inlay
3.Bead blast handle + Marble carbon fiber inlay
4.Black PVD coating handle + Marble carbon fiber inlay
5.Bead blast handle + Carbon fiber inlay
6.Black PVD coating handle + Carbon fiber inlay
Reate Knives would like to talk a little bit about one important techniqueFreeze Edging Skill.
As the final process for a blade, edging has a great effect on the performance of the knives, after all, the edge part is the main function area when using a knife. Normally, edging is operated on a high-speed running grinding wheel or grinding belt, which produces a very high temperature. Without a cooling system, the temperature on the edge goes up instantly to hundreds of centigrade, when it gets worse, it will burn and leave heat marks on the blade. Tempering or even annealing will happen on area of the edge where the temperature increasing instantly. It will harm the hardness and durability of the blade. Thats why some knives passing the hardness standard test but still easily get worn in actual use.
Reate Knives are using the freeze edging technique. During grinding, the temperature on the edge is controlled in a certain level of degree, which helps keep the hardness after the heat treating. Therefore, the sharpness and durability of the blade are assured. This helps bring the performance of the material to the best.
Thank you very much for your time.
Reate Knives Team.
Specification:
Open Length: 8.27”
Blade length: 3.54”
Weight: 150g/5.29oz
Locking:Frame Lock
Reate Knives Team.
