You'll have to wait, JFK, when I'm back in the mountains ....
I'll be looking forward to it......
I have owned several knives during the 24 years I have been spearfishing. I started with a Nemrod Delfín, which I still keep. This knife was very stainless but the steel was too soft to keep an edge and the blade/grind too thick. Then I used a Cressi Sub for a while, which was OK, but the sheath rattled a lot and I eventualy lost it (no shock cord trick). Several others went by, always from diving/spearfishing brands.Thank you for this detailed answer. Which knife has met all your needs among the ones you've carried so far?
I agree with what you said about Folders. I've already stated that I'm not specifically looking for a folder, but I know people who carry folders. I guess it's a matter of experience. I'm an amateur for this.
What?! How come I never thought of this before? It's just as simple as that? I know my dad's camper has a sacrificial anode, and I suppose the row boat also. Hmmm... That's very interesting!If you are worried about corrosion in any knife, you can always get a spent/worn out zinc anode from any boat shop (they will give it to you for free, it is basically scrap), shape a sliver of it and pound it between the molded handle and the blade. Make sure it contacts the blade. Corrosion free guaranteed as long as the anode is there.
There is a knife out there made by a couple different brands (Mares Snake 2.1) wich had a sacrificial zinc pommel that prevented the blade from corrosion.
Beyond being helpful, these are great suggestions, each full of experience. I am grateful for such a detailed answer. Using Zinc anode is the first time I've heard of this and I was very surprised. I will definitely try it. Thank you again, you have been incredibly helpful.I have owned several knives during the 24 years I have been spearfishing. I started with a Nemrod Delfín, which I still keep. This knife was very stainless but the steel was too soft to keep an edge and the blade/grind too thick. Then I used a Cressi Sub for a while, which was OK, but the sheath rattled a lot and I eventualy lost it (no shock cord trick). Several others went by, always from diving/spearfishing brands.
Currently I use a semi-DIY knife. I started with an skeletonized blade (not-so-stainless) that I ground the handle area to get rid of some protrussions and then slapped and contoured homemade yellow micarta scales. Then I made a kydex sheath (pankake style, so it lays flat on my calf). I had to use short stainless Chicago screws to keep it together (with a drop of threadlocker) because the brass rivets where failing. I keep an eye on it everytime I rinse it, so I veryfy the edge. I sharpen it as needed and oil it. Even though I used quality epoxy, the glue has failed, I belive due to water inflitration and tang area rust expanding. But I took them off, cleaned everything and reglued, allowing extra glue to overflow over the tang edge a bit, to allow it to seal. Is not the prettiest, but works great.
I bought a Spyderco Fishunter a couple years ago but this homemade contraption works sooo well and just does not want to die. I also need to make a decent pankake Kydex seath for it, because the provided plastic one is not suitable for calf carry.
Currently, from off the self offerings, if you can afford it, find a Spyderco Fishunter. Being a knife guy, probably any diving knife from diving companies are likely going to feel cheap, the edge will not last up to your standards. However they are not cheap. BE also aware that the tip is very very delicate. You can flex the blade easily with your bare hands. Any amount of prying will probably snap the tip right off. It is a tradeoff though, good for braining, not so good for prying... and the other way arround.
If you want something cheap that works well, despite looking funny... have a look at the BAHCO 1446 2446 FLOAT. I would buy one without hesitation and if you also want to use it to brain fish, grind a point on it. Perfect cheap diving knife, the serration will take care of any cords or netting.
If you don't want to do any DIY work, then stick to the diving/spearfishing knives. Avoid titanium and avoid thick grinds. Any current knife from a reputable spearfishing/diving equipment will work just fine. If you are worried about corrosion in any knife, you can always get a spent/worn out zinc anode from any boat shop (they will give it to you for free, it is basically scrap), shape a sliver of it and pound it between the molded handle and the blade. Make sure it contacts the blade. Corrosion free guaranteed as long as the anode is there.
There is a knife out there made by a couple different brands (Mares Snake 2.1) wich had a sacrificial zinc pommel that prevented the blade from corrosion. It is a dagger, so pretty pointy and not small knife by any means.
I hope these suggestions help you choosing your freediving knife!
Mikel
The Victorinox steak knives (like yours, but fixed blade) is one of the models that the tech scuba divers mod leaving only 2" of blade (chop off the rest) and making a nylon webbing or PVC pipe sheath. I have several at home and cut GREAT! And they are also very very cheap.New update: Another knife recommended here, which I bought out of curiosity, was delivered today....
My browser says that web site does not respond. Anybody else have trouble with it?I leave you photos that I compared with two large folders.
I will buy one immediately.The Victorinox steak knives (like yours, but fixed blade) is one of the models that the tech scuba divers mod leaving only 2" of blade (chop off the rest) and making a nylon webbing or PVC pipe sheath. I have several at home and cut GREAT! And they are also very very cheap.
I was not aware there was a folding knife version of them. I will check them out.
Mikel
If the problem persists, I can upload it somewhere else for you.My browser says that web site does not respond. Anybody else have trouble with it?
I was not aware of the steak knives. I will get a few.The Victorinox steak knives (like yours, but fixed blade) is one of the models that the tech scuba divers mod leaving only 2" of blade (chop off the rest) and making a nylon webbing or PVC pipe sheath. I have several at home and cut GREAT! And they are also very very cheap.
Not sure if you already found what you’re looking for, my go to diving blade (as a knife enthusiast with m390 & Elmax blades in my collection) is the Aqualung Argonaut “spartan point”. It holds a decent utility edge and is indestructible. It also came with a kydex sheath which is really unusual for a dive knife. Mine has been abused pretty badly. It still cuts paper after a few years of use. They used a “beta alloy” titanium for the blade. If you really want a steel one, I’d recommend the Eickhorn S.E.K. I have the double edge military version, but they’re all good knives. They have a glow in the dark version available from Knifecenter if that’s something you’d want to try.Hello everyone, I love freediving from time to time. Taking a knife with me makes me feel safe. I have tried various diving knives so far. My personal opinion is that diving knives are terrible knives. Their hardness is very low and their sheats are generally useless. Their steel is bad compared to their cost. Not to mention the titanium ones, I think they are definitely not knives (I'm not talking about those that are custom produced and hardened in some way). They just look like knives. At least that's what I think about them. At the end of this search, I used Gerber DeFacto as a diving knife for a long time. I had no problems with the S30v coated knife, I cleaned it regularly and there were only minor deformations on the handle. I especially loved the sheath and the simple lock on the sheath but a while ago I gifted this knife to a friend of mine, diving was a real hobby for him and he was using a Labrax brand made in China (OEM). Therefore, I thought DeFacto would benefit him more than me. But now I'm left without a knife and I'm sure you'll have a better suggestion than DeFacto. There are people among you who are experts on every subject. I would be very happy if you could give me suggestions on this matter. I do not plan to go above $150, and low price and high performance would be a reason for preference in a product that I might lose. Also, I don't want it to be a folder. Thank you to everyone who will make suggestions.
Tell me that you want just any old knife when you are in 60 feet of water and you leg gets caught up in a gill net with a steel fishing leader and trip hook on it. I worked as a Diver for many years and until last year lived in Hawaii diving recreationally a few times a month and at work a few times a week. I have been tangled up in stuff on several occasions. When it is hard to see what you are doing and must get free from the tangle or die or help your buddy do the same, the last thing I need is a crappy knife, a pair of shitty shears or a plastic and razor letter opener. Obviously, you have never been in that type of situation.
That's sweet! Nice gear ya got there.I used this one quite a bit in the last few years working as a Diver in Hawaii.
