here is a just a personal evaluation of vic swisstool plus and lm charge ti based on the pictures alone as well as other writeups and reviews.
plier handle (openned):
swisstool plus - (positive) the handles have a good ergonomic design
charge ti - (fair) the handles are straight, but it can be manageable
plier handle (closed):
swisstool plus - (fair) given that they have an ergo design, its normal for it to be bent which is a negative in terms of ergonomics on the blade when in use. it "may" be manageable.
charge ti - (positive) flat which is good when using blades. its also a space saver as well.
plier tip:
swisstool plus - (negative) it claims to have a needle nose tip, but its still not the "needle nose" i expected
charge ti - (positive) i would certainly prefer having a needle nose tip that i would expect to have
blade:
swisstool plus - (negative) i don't find a combo blade very useful for my requirements. in fact i would rather have one straight edge w/o a serated one, or a separate serrated and straight edge, but definitely not a combo or a serrated alone
charge ti - (positive) it has a seprate serrated and straight edge. one hand openning is just a nice to have feature for me, so it doesn't matter at all.
scissor:
swisstool plus - (negative) its quite hard to sharpen since the scissors cannot he "fully openned wide" just like the sak
charge ti - (negative) although sharpening it is a breeze, i found it quite unsafe for openning specially for "thumb pushers" like me. also, they are rather inaccesible since they are found in the inside of the plier handle
screwdriver accessibility:
swisstool plus - (positive) although its a separate component, the positive remark that i gave is based on the fact that it can reach relatively tight spaces
charge ti - (negative) i think the screw driver set is tough to use or rather useless in tight spots
screwdriver bit availability:
swisstool plus - (negative) as of this moment, i haven't found tool bits for vic sold in pieces or sets as far as my locality is concerned
charge ti - (positive) there are bit sets that can be readily bought.
mini screwdriver:
swisstool plus - (positive) its good to have this precision tool separated from the whole tool itself since its easier to handle this small tool for small assemblies
charge ti - (negative) its attached to the bit holder that comes with the tool. i find it awkward to work with small assemblies using big tools
cork screw:
swisstool plus - (fair) i still find a cork screw which is a attached to the tool better than having it seprated from its handle
charge ti - (negative) no cork screw (its really useful when openning bottles)
if i would give 1 for positive and -1 for negative and 0 for fair, this would be the result:
handle: draw
plier tip: charge ti
blade + scissor: charge ti
screwdrivers: swisstool plus
cork screw: swisstool
so far, a mixture of both tools would really give me the 100% go to buy, but then again, i am split into two tools. its really hard to decide on things specially given this preliminary personal evaluation.
give this result, the solution that i see is to buy a charge ti, and the screwdriver/bit set that is sold separately from vic; however, i will loose the functionality of a cork screw and the mini screwdriver. what a tough decision.
again, these are just based on what i have read and seen on the pictures and other reviews as well as what i want in a multitool. i haven't visited my local store yet for an actual hand comparison of both. please correct any of my statements if there are any which you think are wrong. i would really appreciate it.
