- Mar 12, 2013
How do you add the makers mark?
I use a small CNC router to engrave the mark using a carbide 'v' bit... I'm looking into having someone do the marks using a laser though as I think it would come out cleaner.
Well, I'm impressed Aaron. I like the contour handles, I like the drop point and blade shape, I like that it's A2 and that you proved your design through testing, and I like the cerakote. Actually I love all that stuff. This knife is one of my favorite fixed blades out there right now. I will be checking prices and availability later today!
Thats to bad, I want one.
keep posting the youtube vids as well. I enjoy watching them.
Would you sell the grinding jig?
A nice, functional, clean knife, Aaron. Well done. How does the blade finish stand up to usage? I had an old Ka-Bar with cerakoat
, it showed some scratches, but was tough stuff.
Outstanding design Aaron... simple and functional. IMHO exactly what a knife designed to be used should be. you nailed it man!
Hey Aaron Ive learned some things from reading your posts and generally just looking at your pictures. First I need to upgrade my steel i am using the stuff i have isnt even stainless. second use my grandpas belt grinder. thirdly remember for me to drill the pin holes just right because i have messed them up before as well too lol.
Now i noticed someone had said they watched some of your videos? can you give me a link so I can also watch too? I would greatly appreciate it and im sure i would learn even more!
Thanks,
Tyler Jacobs
Hi AaronNo secrets on my end mate! I learnt a lot from people online, so I make a point of sharing everything I learn if I can!
I actually use a jig to do my grinding. Took me about 3 days to make, but it really only required a drill press and some patience, biggest issue for someone trying to replicate it would be the bearing block. I'm keeping that in the back of my head to see if I can come up with a simpler way of doing it. You can see it here: http://imgur.com/a/ffxVM
The technique for the plunge lines is nothing too revolutionary but I believe it's different from what a lot of makers do.
First thing is I use a file guide clamped to the blade to make sure the plunge lines are equal left to right. Then I make sure my platen is dead square in both directions to my work table.
Basically I run the belt exactly at the edge of the platen, using an old file to test when the alignment is right, then I knock the grit off the corners of the belt using the same file. I start with a 36 grit blaze belt, move up to an 80 grit blaze belt, then 120 grit blaze, then 220 grit a/o, then A20 trizact. Every belt is setup the same way, right at the edge of the platen.
Each pass I do actually starts in the middle of the blade, then I work back and touch the plunge, then head back toward the tip.
This seems to work well, I get plunge lines that are identical left to right. Each plunge line is mostly square (which helps it to look crisp) but has a gentle radius right at the corner to make sure that's not a stress riser.
Here is a photo of a blade with the file guide attached, and clamped in the jig:
And the large work table I made for my KMG:
Here are some more results! (Don't mind the wobbly swedge, first one I had done...)
I'll make sure to do a video of the process at some point too!
Very nice. Love your YouTube videos.
