Thanks!
What can we do to keep this finish from wearing off? Is that Cera stuff the way to go? Carnauba/beeswax by Flitz works, but you need to reapply. What lube on the pivot and lock joint?
DonD 729
Hi Don, great to see you here and welcome to Bladeforums!
I'm going to have to research the coatings some more, they would open up all sorts of options.
I have tried Renaissance Wax but any wax or oil will dull the finish a fair bit. The cool thing is after a quick cleaning they will look bright as can be again.
As far as wear goes I think they look cool when the anodizing wears down. The ano finish is harder than the Titanium itself and technically more durable... but if you scratch the Titanium you have scratched the finish.
Windex works very well for cleaning the finish and will make it look new. Another option is a mix of mineral oil and mineral spirits (wd40 works good also) then hand oils will not change the finish as it is already oily.
I'm using Nano-Oil on the pivot and the lock faces are Carbidized. I really like the Nano-Oil, it is great stuff! WD40 is good stuff for breaking in a knife but I like to clean it off and apply one drop of Nano-Oil to the pivot for actual use.
Xander just mentioned a clear cerakote idea... that might be the trick, but Daniel will do a sample for us soon to see how it works out
I'm looking into it right now!
I have a feeling the temperature will have a lot to do with the outcome as high heat will change an ano. But the whole thing has me thinking...
I'm in a rush this morning... more thoughts later!
