Willie71
Warren J. Krywko
- Feb 23, 2013
I appreciate the compliments, but there are so many guys who know so much more than me on this site, that it seems odd to be called Professor. I worry it is disrespectful to them to accept such a compliment.
To explain my previous post since you seem to be interested in this:
Chromium and manganese are added to steel to increase hardenability. Manganese is absolutely needed as it ties up impurities as well, while chromium is optional. The max hardness does not change, but the depth of hardening in the quench improves, as chromium increases the time the steel has to convert to martensite, the hardened state of steel. The difference is quite significant, such as 0.5s to 5.0s with 1-1.5% chromium. (The time it takes to get from the heated state, about 1450f to 1550f, depending on the steel, to the martensite forming temperatures, several hundred degrees cooler.) 13% chromium is the point steel becomes stainless, so we are talking about much smaller amounts. This slowing allows the steel to fully through harden, while simpler carbon steels without chromium can partially harden. This is what causes the hamon. What you are seeing is the transition between the martensite at the edge, and the pearlite higher on the blade (Which forms when the steel cools too slowly to make martensite). Manganese increases the depth of hardening as well. Most carbon steels use about 0.8% manganese, which washes out the transition definition. Steels under 0.4% manganese show the best hamons. My 15n20 is 0.35% manganese, and doesn't have the chromium common in this steel, so it does develop a pretty nice hamon. W2, 1075, and 1095 all have about 0.3% manganese, which is why they are chosen for hamons.
