Three Rough Riders came in on 12/28/19.
(sorry for the long-winded post.)
RR603 Large Yellow handle Stockman. (4.25 inch closed, square bolsters).
This is my second one.
As expected, blades are all arm hair shaving sharp out of the box.
A couple IMHO minor "defects" on this one.
The back spring for the spey/budding is just a hair proud when closed (not enough to feel when holding/using) and is flush when open.
Both backsprings for the sheepsfoot and main clip point are just a touch sunken when closed (again, not enough to notice when holding/using the knife) and are both flush when those blades are open.
No blade wiggle, and no blade rub. (its a two spring stockman, to boot!)
No noticable gaps without a light and/or jewler's lupe. All the pins are flush and smooth. Shield seems tight and well attached/glued.
The pulls on all three blades are a "5" and smooth, with good walk 'n talk.
No half stops.
A good user it will be/is.
RR RR597 Yellow handle (full size 4.125 inches closed) Trapper.
Backsprings are flush open and closed.
I think both blades are arm hair shaving sharp out of the box. (I'm low on left arm hair, so didn't verify.)
No noticable gaps without a light, jewler's lupe or magnifying glass.
Blades are well centered, possess no wiggle, and have a nice smooth "5" pull.
As with the stockman, no half stops.
Another nice user, I believe.
RR1838 "Hopalong Cassidy" "Riders of the Silver Screen" series Moose. 4.25 inches closed.
It is much nicer than the ones I recall seeing as a kid, (made by Camillus? Imperial? Colonial?) back in the 1950's and 1960's.
The artwork under the clear acrylic covers is well done.
Mark side has Mr. Cassidy comin' round a boulder with 6 gun drawn. Pile side has the series name over small pictures of Zorro, Roy Rogers, Hopalong Cassidy, Gene Autry, Red Rider, and Little Beaver. (the other knives in the series feature one of them on the mark side.)
All pins are flush and smooth.
Blades are very well centered. Pull is right around a "5".
There
might be a small less than cigarette paper/toilet paper wide gap between the back springs and liners. (big deal)
This knife has (unexpected) half stops on both blades.
The back springs are flush in all three positions.
The blades are arm hair shaving sharp out of the box.
The "spear point" blade tip looks more "spey blade-ish" than "spear point-ish" but the edge is more spear point in profile.
This should be a good knife to help me decide if I like the Moose or Trapper pattern better, or equally.
Almost forgot to mention. The grinds on all three knives are even on all the blades.
I'll go out on a (sturdy) limb and say "If you want/need a good large stockman, full size trapper, or a "Neat-O!!!" moose, for not a lot of money, you'll be hard pressed to beat these. I highly recommend them."
May y'all have a Happy 2020!
