JTknives
Blade Heat Treating www.jarodtodd.com
- Jun 11, 2006
Ever since I watched the peters heat treat vid I was fascinated with fluid bed heat treating. I have been kicking around some ideas and being that the heat treat oven is just about done I guess that means it's time to plan the next project. I had acquired all the stuff for a salt pot but decided to do an oven. But now I was thinking and think a small scale sand pot could work. And I have just about everything to test it out.
My thought is to take my salt pot tube and weld a base on it and then use 316 stainless tubing and weld it to the base. Cut a hole in the top of my verticle forge cover plate and suspend the tube just like you would a salt pot. My thought is to maybe coil the 316 tubing around the sand pot and then come up and out the forge top. I have about 35gal of silica which is just refined silicone dioxide aka sand. It has a melting temp of over 3000°. The stuff I have is very very tini balls, lab grade silica.
So I would fill the tube with the "sand" and fire up the forge and start heating the sand tube. Next I would pump gas into the 316 tubing which causes the "sand" to bubble and create a very even heat. The gas can be nitrogen like peters heat treating uses or argon or if you don't mind scale it could just be air from a compressor. My first test will be from an air compressor and if it works I will go with a shealding gas. With nitrogen you now have an environment that will not oxidise the blade. The gas will need to be regulated to a low flow so you eather don't create a flaming shotgun air cannon and also don't cool the sand to much. But if the gas going down the tubing has enough time to warm up before entering the sand pot I think this will be mitigated.
So what's your thoughts, am I bat shit crazy?
