JTknives
Blade Heat Treating www.jarodtodd.com
- Jun 11, 2006
It will be interesting to see how well your able to heat it with electricity. The math says it takes almost 27KW of power to equal 1gal of propane. We pay 9-10¢ a KW so it's about the exzact same price as propane per gal. The advantage of Electricity is you can seal all the heat in which makes it more efficient then if you used propane. But I'm wondering if you can overcome the heat loss of the exposed sand and then adding the steel to the mix. The advantage of propane is we can easily up the BTU/HR input. With electricity you have greatly increese the amps.
Just for giggles if we used say 2lbs of propane an hr (10hr run time on BBQ size tank) which I think is less then we would need but it's a starting point. 2lbs of propane is equivalent to 43,200btu/hr. 1KW is equal to 3,412btu/hr so This means you would need 12.66KW heating elements to equal the propane. This would draw 57amps of power on a 220 circuit. Now electric will be more efficient because it's sealed but I don't know how much more. Heat treat ovens are really efficient but thy are fully sealed where a sand pot is not. You basically have a 6" opening in your Sealed system. Yes we don't have much air circulation besides the air being pumped in from under the defuser plate. So even if it was say 30% more efficient then propane your still going to need 8.86KW elements and 40amps of power at 220.
All these numbers are based around my origanial assumption of 2lb of gas used per hr. I honestly think it might take more depending on how big it is and how much castable you got in there. 2lb/hr is quite good for a small forge and if you crank that small forge up to 11 your lucky to get 5hrs out of a 20lb bottle which is 4lbs/hr. If that is the case for this sand pot and it's not 2lb but 4lb/hr then you just jumped from needing 40amps to 80amps.
I'm not trying to piss on your corn flakes at all. Mostly just trying to see for my self how practical using power is with the limited power most shops have on hand.
