Would be fun, I have been wanting to try one of your rose pattern jelly roles.
Ok guys construction has started. First I need a top and bottom disk to seal off the heating chamber. The top is 304 and the bottom is A36. Being that I'm on a budget and that I own a plasma cutter I figure I would save the $100 and cut them my self. Because I used 2 different materials the metal shop wanted to charge 2 set up fees of $45 plus cut time. I said no thanks I will cut if at home with my plasma. So I was scratching my head on how to cut a nice circle. I thought I could use a string and sharpy and make a line and then hand cut that. But what if I connected the plasma to that line. And what if the line was steel.
So this was born, I have 3 holes. Small hole is .25 that takes a 1/4" carbide locater pin and the other 2 fit the tip of the plasma and are spaced to make my 17" and 4.5" circles. I started with the a36 as it was much cheaper to mess up.
It works rather slick if I do say so, so I kept cutting.
First disk cut. As I cut I got a better feal for it and was able to speed up and create a much smoother/clean cut.
Finish is not to bad all things considered.
If I'm being nit picky which I am, I need a 16-7/8" disk and I cut a 17" disk.
Next up was to tackle the stainless 1/4" 304 plate. Because need to use the corners of the sheet I used the cut disk to lay out the optimum center so I had little waste.
Cut without a problem. Stainless cuts different and the dross from the cut is not hard like on carbon steels which makes just popping it off problematic.
Next I wanted to clean up the plasma cut edges and bring them to perfect size of 16.875. So I set up my tool rest so the edge of the rest was exactly 16.875" away from the rest minus half the Diamater of the carbide center pivot.
Next I set the disks on the rest and ground the edge till the center carbide pivot pin touched the edge of the rest. Then I just turn the disk around the center and presto a perfectly round ground surface.
And presto a perfect 16-7/8" disk
Then because I am who I am I set the rest at a 45° angle at a measured distance away from the belt so I could do the same thing to the disks but this time chamfer the edges evenly.
And there we have it. Might be crazy but I take pride in my craziness.
Using the jig I cut the 4.5" hole for the sand pot.
Oh not bad if I do say so my self. I actually measured it with callipers later and it's dang close at around 4.520-4.535.
Here is the pot in the 4.5" hole. Fits perfectly with just enough resistance to keep it from falling out. It will be welded into place to create a sand proof seal.
I also cut out the clearance hole in the bottom disk for the air supply pipe.
I will resume the build in the morning
