JTknives
Blade Heat Treating www.jarodtodd.com
- Jun 11, 2006
Ok guys I have been back at it and I think I actually have some useful information now. I located a company that makes them for labs. Thy don't go high enough in temp for what we need but thy are rated up to 1100°. But the principle is the same and it gives us a starting point. One thing is quite clear, which I have started to discover in my testing and this is the deeper the pot the larger the Diamater needs to be. I noticed that as I moved the bubbler lower and lower into the sand the bubbles changed and at full depth I had just one big bubble. But closer to the top I had lots of tiny bubbles. I think what's happening is the bubbles are merging as thy are raising. I was not able to get any information about there disturber plate from there site. Here is some screen shots I took to show what I found.
First up is there models and specs for them, you will notice 2 important chunks of data in these specs. First is the size of the pot and second is the max flow rate. Thy just use air and I don't know what thy mean by max flow rate besides that's the max it can adjust to. I would think it would run somewhere between none and max but I don't know for sure but it gives us a starting point. But notice the pot size, if you want deep you get larger. This is also shown in the peters heat treat video. So is it just that people want larger pots with depth or is it that deep pots that are skinny don't work well. I'm more inclined to lean towards the latter after my testing.
Thy have some good videos on there site that explain some things and how it works. It opened my eyes To the fact that I was going after a fluidizing level that is not practical. If you watch these video I link below you will see that it's fluid but not crazy like I was trying to get. It just slowly allows the basket to sink into the sand. This must not be a problem because look at the specs and the amount of heat control thy have.
https://vimeo.com/154776445
Thy also say thy use 90um aluminium oxide which is .0035. Thy also sell the sand in 100lb buckets but it's pricy at $250. I don't know how it's graded or if its just "medical grade" 120grit aluminium oxide.
Here is there sand thy sell
https://www.instrumart.com/products/39876/accurate-thermal-systems-ats1027-aluminum-oxide
Another thing I noticed is thy are using 304 stainless 14ga welded pots. Thy offer 316ss pots but only if you are doing corrosive stuff. In my research it seemed like 304 can handle heat a little bit better but I never actually found tensile strength at high temps.
Another thing I noticed while watching some of there videos is that it's normal for sand to shoot out and make a mess lol. So in our design that is to be expected but the rased surround should keep the mess to a minimum. One thing thy have that I never really thought of is a cover, there's is insulated. I don't know if we need one or not but it would not be hard to incorporate one. I think there's is mostly used to control the flying sand.
Here is a PDF for the model I think we are best trying to deplacate 7x25" pot and has a way to control flying sand.
http://accuthermal.com/wp-content/u...SL12-FTBSL26-Fluidized-Bath-brochure-rev7.pdf
So that's it for now but I think we need to look at going to around 8" for our pot size but 6" would be better becaus the price for 8" skyrockets.
