Ok I did a little testing and have mixed results. The testing befor heating went amazing, nice and fluid at a low flow rate. Then I started heating and holly crap this aluminum oxide was releasing some noxious fumes. About choked me out when I went to look inside the pot. Had to step out of the shop till it was burned off what ever it was. It was not pleasant at all, but after it got up to temp it was all gone and ok. So let that be a warning to you guys. I don't know what could be burning but I'm guessing it's some impurities from manufacturing. When I got choked out I shut off the air to the sand and stepped out side. This was a mistake I think because the sand kinda clumped up in the bottom and messed up my fludizing effect. Also the grains look clumped together. I had a wad of kowool in the bottom and the sand clumped onto it because the air was not flowing. So I am letting it cool down and I'm going to start over and keep it circulating the entire time it burns off. I could tell I had a problem because when it was at temp it was not mixing and it was chugging bad when I would turn it up to increase the flow. This told me one of 2 things. 1- I have a plugged bottom and air is forming a large bubble or 2- the heavier sand needs a larger diamater pot to reduce the chugging. The air was flowing along and up the side of the pot. So I'm guessing there was a hole in the clump at the bottom at the side of the pipe. So once it's cold I will reset and start over.
I found locally pure aluminum oxide and SIC and for free .......what I read here is that grain size 100 /which a 0.13mm average size / is ideal for this .But before I start to make sand pot I need to know something .JTkinves , in your setup how much time it take to get say 1500 F ? I don t HT many knives at once , most one and that in a month...so I need to know what is the cost ...Thanks in advance :thumbup:
