Spent last week atmy daughter's home and had a day in Auxerre, nearest large town. Could not get home without visiting the cutler (the red corner shop) Gouvernois and get a local Auxerrois! The pattern is common to the Tiré-droit, with a spear instead of a sheepsfoot.
:thumbup: the choice was easy for me, I needed an ebony!Wow love those I would be in trouble going theretoo many to choose from!
G2
Yes, there are many houses like this one dating from middle-age, they have seen the hundred year war and the fight between Louis XI and Charles the Bold of Burgundy. Auxerre is a very old little town, with intricated streets, used to be healthy thanks to wine and farming, and in the past for printing works and wood floating on the Yonne river. Today it is best known for the football team.Sorry, I had to copy it yet again. Beautiful knife, wonderful window! Is that corner building as old as it looks?
Laguiole as most peasant knives were primarily used for cutting bread, in the fields or down in the coal mines for lunch, then home for dinner. At lunch the bread served of plate, and in the evening, the slice of bread would be as large as the soup plate, and the broth was poured on it, and sometimes at the end of the plate a bit of wine. So the usual size was over 12cm, for two reasons, this allowed to cut a large slice of bread in one time and also because on a large blade, if a part gets dull, there is enough sharp remaining.Thanks Barrett. I could be wrong but I believe a few makers make an 8 cm as well. The 9, I believe, is the more common small version. Im still in the process of learning more about these.
I debated it for a for months. It just seemed to small from various pics. The handle height compared to the width is certainly different than I am used to. However, the width is what saved it for me. If was thin I do not believe I would like these as much.
Over all I really am impressed by these. The only critic towards the negative is the half stop, if it is even called that in these, doesn't allign in the postion on each.
Im really glad I picked these up. I plan to get another pattern later.
Thank you! You don't need to go to Switzerland to find thes B...S..t! On a lot of markets and in a lot of tobacconist you can locate them. Alas... The name is not protected. Though, you check the knife, the difference is clearly visible. Now it is up to you. Do you want a quality knife or a cheap one??Hello! Sorry to disapoint (all of) you but all the Laguioles on the displays in the back are not French! Bougna knives are made in Pakistan. Here in Switzerland I often come across stands like these on markets, the average price is around $20-30. Also watch out for the brand "L´Eclair" who are also made in Asia. Un bonjour de Villeneuve, Michel Droz.
Thank you for your interest. This is a special pattern made for the shop, but it is a way between a tonneau (barrel) and a tiré-droit (pulled straight) with a pen blade instead of a sheepshoot. It is 9,5cm and they are made with/without corkscrew. (I prefer without, it is more streamlined). fairly heavy for the size.(89g - 3,14 ounce) The stainless blade cuts and cuts and...
tonneau (always with cs)
