I'll have to disagree that a 15 degree edge is universally too low. I have other machetes that will hold this edge angle without damage, and they are longer and/or heavier and hit much harder than the Barong. I've also seen and talked with people who have used axes all their lives and use edges thinner than 15 degrees. I'd agree that fine grits generate less heat, but the reference was done on 1000 grit paper and generated temperatures over 2000 degrees, by hand. I don't think it makes a difference what grit isused with respect to the last microns of the edge.
It's odd that you and many others use such a variety of grits to sharpen on a belt sander. You would think a narrower range of grits would come out as better than others. I typically use a VERY worn 180 grit belt. I've been using it for 4 years or so now. I've seen people here and other forums use everything from 80 to 1200 grit, which I used for a while until it was damaged during an acid spill. I also power strop with a Surgisharp belt with white compound.
