Silly question?
I know this is ridiculous but I have ocd and checked over a knife and noticed a couple of tiny holes that could only be picked up with maximum zoom on my phone camera. Are these normal? Thanks.
https://pasteboard.co/JAI19sN.jpg
https://pasteboard.co/JAI0oHf.jpg
https://pasteboard.co/JAI0BFv.jpg
https://pasteboard.co/JAI0O2u.jpg
https://pasteboard.co/JAI0Zq9.jpg
MnDpgpF
I can't say if they're normal, I don't generally look at my knife blades under a microscope.
This may be an example of too much technology NOT being a good thing.
I don't think those tiny "holes" are anything to be worried about, especially if they are just in an outer blade coating.
you should check out the random
surface pits on low end steels found on
prc cutlery.
i figure the odd few pits could be structural,
and not marks from abrasives materials used in the manufacturing
processes when fashioning
or finishing a blade's aurface..
just my 2 cents
My willingness to overlook things is inversely proportional to the amount of money I paid for that object.
Translation - on a $50 and under knife, I can overlook that. Once it goes over $50, I start wondering what's up because I have plenty of cheap knives that don't have that flaw.
Any chance it is just the coating? Otherwise it is clearly a defect in the material.
I had a Victorinox chef knife and I noticed a chip on the edge. But it didn't look bright or shiny by any means, more of a brownish color. I put some pressure on it with my thumb nail and a lentil sized chunk of steel crumbled. It was clearly a defect from the steel stock before the knife was made. I took it to the cutlery store and they basically butchered the knife with a regrind instead of replacing it. So it has now basically no belly at all, so it is pretty useless for chopping veggies on the cutting board.
Mikel
It's not a silly question but going OCD on a mass production knife might be. Mass production is just that : produced in mass and that means quality checks are done by batches. The higher the mass, the lower the price and the larger the batches... So, yes, many things can go wrong from one QC to the other. This said, going all microscopy on a + 50 $ knife seems very OCD. If it's not a structural defect, live with it, use the heck out of your knife and think of the next knife you will buy.
Maybe - maybe not.
A CRK - $375 - $450 is a mass production knife.
I spend that kind of money, and I expect it to be next to perfect.
As I mentioned before - my propensity towards flaws of any kind goes down as the price tag goes up.
Not silly , but also not a problem , IMO .
Advise stop worrying and go out cut up some stuff ! :cool::thumbsup:
MnDpgpF
Those are not normal. They are more than unsightly, and are, in fact, down right dangerous.
Send the knife to me and I will dispose of it safely.
Looks like a blade coating to me ? If so you can strip it. You can easily change the finish with a Dremel and some polishing compound.
you sure the "holes" ain't specks of dirt or something?
Even "mirror polished" steel won't be perfectly diamond/crystal smooth. Small indentations and scratches are "normal".
I see nothing to worry/fret about or lose sleep over.
None of those "holes" go all the way through the blade stock.
There are no micro cracks that could potentially cause the blade to break if you baton it, or beat a block of ice, or antler/bone, or otherwise abuse the knife, as routinely done on 'FORGED IN FIRE'.
I seriously doubt if you sent it back to the maker or dealer they would find anything wrong with it that would justify repair, replacement, or refund.
Unless I'm missing something, you were happy with the knife until after looking at highly magnified images of the blade. With proper care, no abuse, no over sharpening, etc. I don't see any reason why that knife won't last several generations after you.
Just so you are aware, nothing made by or designed by humans is "perfect", regardless of cost.
As my (maternal) great grandfather (1892-1974) used to say: "Expect perfection; be eternally disappointed."
By the way, as a former auto body repairman, I can tell you that if you magnify a random spot/area of paint on your vehicle enough, you will discover gaps with no paint larger than those "holes".
