Rob Simonich :
for those looking for a very well balanced stain resistant steel, this is looking pretty good so far.
Yes, pretty much exactly.
never judge a steel by its spec sheet
The base materials properties of course don't tell the whole performance, however it is hardly like they can be ignored, they were developed for a reason and well characterize the aspects they measure, just like hardness measures compaction resistance. There are literally thousands of cutlery grade steels, any maker (or user for that matter) who doesn't want to spend his entire life just moving from one steel to the other every few days has to use something to discriminate among the steels that they have not used in order to seperate the ones that are promising from those that are not and focus on the ones that look to give the most benefit, otherwise you would never get anywhere.
No, I have not used a S30V blade, the properties that Crucible have promoted are of no interest for me for reasons described in the above. I can easily list off over a dozen alloys now that for similar reasons have no interest to me, and I am sure that it would be trivial for others to do the same. If I hear that the properties of S30V are different as more blades are made out of it then yes my opinion might change. However I don't think it is reasonable for anything like that to happen as it would mean that it had either a toughness greater than 3V, or better low stress edge retention than S90V, or extreme corrosion resistance akin to 440A.
As for material properties, the way they are used correctly is not to simply to look at them as numbers on a piece of paper. They only become meaningful when you correlate them to actual experience with that material. It is the same thing with anything. For example once you know the properties of A2 and have worked with it quite a bit you then understand what those numbers mean in regards to such things as edge retention, edge durability etc. . They are no longer then just numbers on a sheet of paper but a way to quantify the performance that you have seen in use.
This by the way is something that everyone does in every day life. It is nothing more complicated than knowing that you like the taste of one tablespoon of sugar in your coffee. Once you have come to this conclusion you have now correlated a precise measured standard (one tablespoon) to a personally meaningful quantity (your desired sweetness). Thus when you order coffee you can specify a particular quantity of sugar, which is a rigerous standard, and not a judgement on sweetness which pretty much no one really understands but you. The material properties of steels allow the exact same types of decisions.
The complicated part about steels is the way that they intereact. For example edge retention is dependent on the impact toughness, ductility, hardness , wear resistance, and carbide structure. And what is even worse is that the dependancy is different depending on what is being cut. Chopping wood for example requires a very different set of properties that cutting fibreglass insulation. Decisions can still be made though once the various factors are considered. For example if someone asks you for a better knife for cutting the insulation that a 60 RC A2 blade they are using, you can provide once in D2 at 62 RC with confidence that the extra edge strength and wear resistance will give them the performance they need.
This is also obviously why Crucible went the way they did for the spec's relating the performance to well known steels instead of just stating numbers (toughness like A2 instead of -> a c-notch charpy value of ~40 fl.lbs) . However how to you think they determined that it had a toughness similar to A2, by a charpy test, same thing for wear resistance and corrosion resistance. There are well developed standards for measuring these quantities and they are vigeriously used in the development of steel alloys (and for lots of other ones as well including the non ferrous ones) and they allow a very rapid rate of progression in the development of alloys.
-Cliff
