- Sep 20, 2015
Thanks.If there is a coating, it should be easy to detect/remove with a few strokes on a fine abrasive stone.
I left the red scotch brite pad out in the back yard to let the Zylene evaporate for a day before I brought it in.
It did have a white residue on it where I had been using it to scrub with.
I did abrade the heck out of the HAP40 area of the blade using my Shapton Glass Edge Pro stone. I forget which one but it was either my 220 or 500.
I was starting to get the factory grind pattern to smooth out but was only through it in areas and looks like those are the blotch areas that I got when I tried to patina it again. Any one wanting more detail about what I have already done to chemically and mechanically prepare the surface should follow the link above to that thread.
Thank you !I have only wiped down my HAP40 blades with 90% rubbing alcohol. After that they took a patina just fine. I truly think there is just oil on it.
Maybe it is alcohol based. Many solvents won't touch finish that is dissolved with alcohol. Obviously I am no chemist . . . I'm just saying.
It seems like it should be really simple to end this thread. All it would take is a person from Spyderco (Sal) to answer my question.
. . .or check one ? :
- It is an industrial trade secret.
- You are nuts there is no coating.
- I don't know.
