In no particular sequence:
1. Stretch 1 with Micarta Handle and CruWear, SRS 13 or K390 blade, lanyard hole delete
2. Native Chief Salt. Orange G10 LC200N
3. Schempp Bowie with Ti bolsters and denim Micarta scales, blade steel could stay S30V or be upgraded to Cruwear or LC200N, lanyard hole delete
4. Stretch 1 or 2 Salt LC200N with G10 scales, flat grind and in both PE and SE, and Combo edge with Serrations in the middle of the blade with 3/4 plain edge heel and tip
5. SpydieChef XL-- 4.5 inch blade same Ti RIL/ LC200N construction beefed up detent -- may needs beefed up clip too, lanyard hole delete
6. Shaman with Ti bolsters and end caps (Only drilled and tapped to order for clip orientation), polished linen Micarta scales and uncoated 4V or V4E, lanyard hole delete
7. Could also go for VashHash's "Spyderco Kris with white linen Micarta scales"
8. Native XL-- Same style, back lock and linerless G10 construction as the Native and Chief-- just sized in between (3.5 inch blade with 3 inch edge). Size of a Shaman with regular Native construction. CruWear as a production steel. Introduce with a Salt version in LC200N and bright orange or green G10
9. Native Salt G10, linerless blaze orange G10/ LC200N
10. Slysz Swayback with 4V (Overkill, you say... but, we know Taichung knows how to handle it)
11. A new Ed Schempp design with a backlock, 50/50 choil, bolsters and contoured micarta handle; blade shaped as a Stretch type drop point with lots of negative blade angle
Jeez, could probably keep going but will call it for now. Oh, and fixed blades...?
