I tried hand sharpening but I could not get the hang of it. The issue with sharpening is that even if you decide to do hand sharpening good stones become expensive. If you own many knives a good system pays for itself. I have about 60 knives left in my collection after selling off about half so for me it was a no brainer and at some point I’m going to acquire a Tormek but for now my KMEHi, many thanks for your advice: I had no idea that it could take up to an hour to do it right! However I WANT to learn how to do it right and am willing to spend the time I need to in order to practice and learn. I have a good strop block and compound as well as the Fallkniven sharpening stone. I think it best - based on what I have read from you and Gary - to practice on cheap knives (I have a super-cheap Buck folder and will get a Mora) before I do anything with my expensive ones. The KME system looks interesting but it is a big investment. I would prefer to learn how to hand-sharpen but will default to KME if I cannot learn hand-sharpening properly. What would really help would be to have an expert watch me and teach me but that is not likely to happen in the near future because of COVID restrictions.
I've had a KME for several years. It is a very good system. But you do not need it and you do not need to spend a ton of money on free hand sharpening.
You want diamond for M390. So...
1. Ultra Sharp DC38 8"x3" 300/1200 combination diamond stone = $70USD
2. Universal Stone Holder = $20
3. .5um Diamond Spray = $20
4. Red Sharpie = $3
5. Paint Stick (for strop) = Free at big hardware stores
I actually prefer 300 and 600 grit but Ultra Sharp doesn't offer them in a combo. The 2-stone kit is $77 if you want to go that route.
For re-profiling I would recommend a Baryonyx Manticore. No it is not diamond but it is so course you'll be fine. Shipping and all will be about $30. That is for serious material removal. You can really lean into that stone and change bevels quickly. I would not recommend this until you know what you're doing. Don't be concerned with re-profiling until you can sharpen consistently.
It should not take any where near an hour to simply sharpen a knife. You can spend a ton of time on the KME because one, the stones are small so it takes more strokes to achieve the same burr as a large bench stone and two, because people get caught up in re-profiling and grit progression. But don't stress time. When starting out it is irrelevant. It takes you as long as it takes you. These days I can sharpen most any of my knives in around fifteen mins tops.
Paint your bevel with the Sharpie and run it on the stone. If it mostly comes off the shoulder and not the edge, you're too low, If mostly off the edge, too high. One or two strokes, check, adjust, re-mark, verify and go. Try it on a pairing knife to start.
Raise a burr the length of the edge. Now do the other side. Then some very light edge trailing strokes to de-burr. Then very light edge trailing strokes on your spray-coated stick to refine.
Start by only using the 300 grit. It must be sharp off your lowest stone or you're wasting your time moving up. There will always be a little re-profiling as that is just the differences between you and the factory but nothing major like changing angles and such.
Watch some videos. Dean O has very good manual and KME videos. Outdoors55, Rough Rooster Knife Sharpening and tons of others out there too.
Go to this forum's Maintenance, Tinkering, and Embellishment sub-forum and read the stickies at the top. Abuse the search function. And ask any questions you have. Great folks hang out there with tons of knowledge.
Many thanks, Eli - this sounds like a great way for me to start.
Untitled by GaryWGraley, on Flickr
